Digital distortion issues with Studio after 3 minutes of playback
I’m experiencing a specific and reproducible issue when using Studio with my Dangerous Music Convert 2 DAC over USB. Here are the details:
Issue:
  • Digital distortion begins around the 3-minute mark during playback
  • Affects all audio tracks, no matter the source (local library files and streaming)
  • Distortion sounds like a clocking error and progressively worsens over time
  • Problem persists regardless of sysOptimizer status or buffer settings
  • Temporary fix: Rebooting both computer and DAC resolves the issue!
System Setup:
  • DAC: Dangerous Music Convert2
  • Computer: iMac running High Sierra
  • Connection: USB
  • Previous setup: Same hardware worked flawlessly with Audirvana 3.5
I find it particularly interesting that this wasn’t an issue with Audirvana 3.5 using the identical hardware setup, which suggests it might be related to Studio’s USB handling.
Has anyone encountered similar issues or have suggestions for troubleshooting? I’d appreciate any insights on potential solutions beyond the temporary reboot fix.
Thanks in advance for your help!
Welcome…
Please paste your debug information report here, so folks can help the best possible… It is found here: Settings–> My Account–> Help–> Debug info
Something else is going on with your system…
I’m running macOS Sierra 15.1 and Audirvana Studio 2.9.4, playing 24/352.8kHz AIFF files, with Audio Units HRTF DSP being applied to all PCM files, and subsequently modulating (upsampling) these files to 5.6MHz DSD128 via r8Brain transmitted via DoP 1.1 , output on the USB 3.0 bus to my DAC. (USB 3.0 → USB 2.0 to the DAC)… I have been listening without the behavior you are experiencing… In fact, my first impression of the sound-quality of Audirvana 2.9.4 is having an incremental improvement in contextual detail and focus!
See my screenshot below:
Thanks for your reply! I’ve pasted my debug information below. The fact that it all works fine after a reboot is proof everything is compatible and the settings are ok, but it’s a real killjoy to have to do that every time I want to listen.
Audirvana Studio 2.9.4 (20904)
macOS 10.13.6 x86_64 with 4GB physical RAM
Connected account of : MJA
AUTO: /Users/MJA/Documents/Music
Library database path: /Users/MJA/Library/Application Support/Audirvana/AudirvanaDatabase.sqlite
Tracks with no MBID: 128
Listening on 127.0.0.1 on port 49163
TIDAL: Connected as PREMIUM
Font size: regular
My Music
Radios
Podcasts
Streaming
Use Apple Remote: yes
Number of paired remotes: 0
Screen saver disabled: no
Max. memory for audio buffers: 1024MB
Local Audio Engine: CoreAudio
Exclusive access: ON
Integer mode: ON
Use max I/O buffer size: OFF
Dangerous Music CONVERT-2 [sn2189]
Model UID:CONVERT-2 [sn2189]:20B1:3040
UID:AppleUSBAudioEngine:Dangerous Music:CONVERT-2 [sn2189]:2189:1,2
Device: 2ch Non-mixable linear PCM Interleaved 24bits little endian Signed Integer, 8 bytes per frame 44.1kHz
Hog Mode is on
Selected device:CONVERT-2 [sn2189]
Manufacturer: Dangerous Music
Model name: Dangerous Music CONVERT-2 [sn2189]
Model UID: CONVERT-2 [sn2189]:20B1:3040
UID: AppleUSBAudioEngine:Dangerous Music:CONVERT-2 [sn2189]:2189:1,2
USB Vendor ID: 0x20b1
USB Product ID: 0x3040
ID 0x27
Stream ID 0x28 2 channels starting at 1
12 virtual formats:
12 physical formats
Device #0: ID 0x32 Built-in Output
Model UID: AppleHDA:78
UID: AppleHDAEngineOutput:8,0,1,2:0
Device #1: ID 0x27 CONVERT-2 [sn2189]
The Audivana System Requirements may be relevant, given that you are running at the very minimum memory requirement of 4GB where you are allocating 1GB of your System RAM for playback preload buffering… Try lowering your playback preload memory allocation to 500MB or not allocating any amount of your System RAM for playback buffering.
Configure this setting to reflect: "Use max I/O buffer size: ON "
Note: When there is not enough System RAM for the CPU operations, it is forced to use ‘virtual memory’ on your System drive if there is space on this… "disc swaps’ precipitate interrupt wait-times in the CPU operations and they can precipitate loss of sync issues due to bus management buffer under-runs… And these interrupts are compounded by storing the Music Library files on the System drive.
