Hi.
How does Dirac plugin work? Dirac run max 192. Can use Dirac plugin and upsample to 384? Does the upsampling happen after the Dirac plugin?
Hi.
I have a similar question. When I upsample a 44.1 file to 352.8 (x8) the Dirac live window says “no signal”. When I change back to 176.4 (x4) the no signal warning goes away and I can select filters again. Is this normal behaviour?
Hello @DonR,
You should reach out to Dirac about it as they are in charge of the development of the plugin. If they have a question about what is going on, they will contact us since we have a partnership with them.
I did as suggested and Dirac have confirmed that there is a limit to the sample rate that is supported by the Processor and it’s 192 kHz.
If you would like to upsample to a higher sample rate, you might consider Studio. here the DSP is performed before the upsampling.
