I just in the migration process from iTunes/Music to high end player such as Audirvana
I have 2 huge libraries. one Pop and one classic. I added both to Audirvana. What a mess… In all views they are mixed together. Rolling Stones tracks and then Mozart and so on. This is specially annoying when using the shuffle mode. Imagine I have guests addicted to classical music. In the shuffle mode Glenn Gould is playing Mozart on piano. The next song played is from Deep Purple. As a result my guests are leaving…
Any ideas how to handle this? I have tried with playlists. Not really feasible since each library contains 5TB of music files.
I’m looking for a button in the library management where one can just enable/disable a path/library.
Make smart playlist…
One name pop and other Classic
Just drag pop Music folder into pop smart and the same for Classic smart, voilà
When visite comes, random play either playlist
Thanks RunHomeSlow for your reply. Since reading I tried very hard a folder (meaning the whole library at once) into the a smart playlist. I can’t figure out. Sorry maybe I’m a bit clumsy. I’m using Origin 2.5.16. The only way I see is to select each album from a library and then drag it to the apropriate playlist. But since the album are sorted in some way but not by libraries this is a Sisyphean task☹️.
Firstly my first 2 pictures is how my hard drive is set up for Audirvana…
i figure yours has a Big folder MUSIC??
containing 2 other folders named: POP and CLASSIC
Then, you create a smart playlist for each folder, that way whenever you add something in POP or CLASSIC, it will be automatically added to the smart playlist…
see third picture, just change the path to correspond to your computer
