Distorted hiss sound
First day after yearly subcription, Today while listening music from Tidal the music stopped and a loud hiss like distorted sound came out of my speakers. I was afraid for damage in my speakers (but ok it did not happened any).
Why I experienced this disturbing issue please?
Audirvana Studio 2.9.0 (20900)
Windows 11 (22631) with 16GB physical RAM
Connected account of : Tasos Datsis
Available network interfaces:
Hello+Goodbye ({586c0f51-5e7d-4790-a359-3fc15152db80}) is PUBLIC
Active profile types: all
Private profile:
Firewall: enabled
Inbound: blocked
Outbound: allowed
Notifications: enabled
Public profile:
Firewall: enabled
Inbound: blocked
Outbound: allowed
Third party firewall installed and registered in place of Windows Defender:
Kaspersky Internet Security
AUTO: C:\Users\adats\Music
Library database path: C:\Users\adats\AppData\Local\Packages\Audirvana.Audirvana-4118-9684-d80dbb7827cd_q3nymrkmej12j\LocalCache\Local\Audirvana\Audirvana\AudirvanaDatabase.sqlite
Tracks with no MBID: 235
Listening on 2a02:85f:e818:60ca:4f42:d2e9:fc3b:59cb on port 60796
TIDAL: Connected as PREMIUM
Font size: regular
My Music
Radios
Podcasts
Streaming
Number of paired remotes: 0
Screen saver disabled: no
Active method: Chromecast
Preferred device: [Chromecast] Καθιστικό
Model UID:Primare CD15
UID:DnsSd#Primare-CD15-fea380caf80c7f3e3574b281573b1789._googlecast._tcp.local#0
Currently playing to Chromecast device at 16 bits 44.1kHz
Device: 2ch 16bits Integer, 4 bytes per frame 44.1kHz
Selected device: Καθιστικό
Manufacturer:
Model name: Primare CD15
Model UID: Primare CD15
UID: DnsSd#Primare-CD15-fea380caf80c7f3e3574b281573b1789._googlecast._tcp.local#0
Volume control: Yes
Max volume alert: Disabled
DSD via PCM 1.0
Override device declared HiRes capability: OFF
Chromecast devices found : 2
Device #0: Καθιστικό
Device #1: Τηλεόραση στο υπνοδωμάτιο
Model name: KM7
Max. memory for audio buffers: 8192MB
Local Audio Engine: WASAPI
Device #0: Speaker (Realtek(R) Audio)
Manufacturer: Realtek
Model UID: INTELAUDIO\FUNC_01&VEN_10EC&DEV_0236&SUBSYS_103C899B&REV_1000
UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{82f270b8-9a58-4d4a-99d9-8311a43da353}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
Model name: Intel High Definition Audio\nnUPnP
UPnP devices found : 1
UID: uuid:503ea556-b1da-11ec-afcd-f5db25964478
Manufacturer: Primare
Model name: PrimareCD15
Hi @Tassos_Datsis,
Are you using Primare’s latest firmware on your device? Have you tried using UPNP instead of Chromecast?
Yes I am using latest firmware. I have used both UPNP and chromecast. What is your suggestion? Both options work well I think. Do you believe that the problem had to do with the streaming option?
Do you have the same behavior if you try to reproduce the issue with local tracks?
Only one time I encountered this problem all these days that i am using audirvana. Another couple of times Audirvana stopped without any obvious reason and shutted down! And another time it was frozen and needed restart!
