Hello All-
Got a new D70 Pro Sabre DAC so I can run DoP 256. I am on an M1 Pro MacBook Pro. On first launch of Audirvana, I was able to properly play DSD files to my dac. Now I am just getting a static sound coming out. Not sure what happened… Any advice?
Welcome…
More information is needed regarding your connection to the DAC…
Please paste your debug information here in this thread so folks can help the best possible… It is found here: Settings–> My Account–> Help–> Debug info
Verify that Audio MIDI Setup is reflecting the PCM maximum of 768kHz for the DAC… Shut-down the computer, shut-down the DAC and then reboot the computer, power-up the DAC and then restart Audirvana…
Hello-
I checked the audio midi setup and it is on the highest version. Debug info below:
Audirvana Studio 2.9.3 (20903)
macOS Version 15.1 (Build 24B83) ARM64 with 16GB physical RAM
Connected account of : Daniel McCormick
Local network access: forbidden
AUTO: /Users/xxxxx/Music/Collection
Library database path: /Users/xxxxx/Library/Application Support/Audirvana/AudirvanaDatabase.sqlite
Tracks with no MBID: 1
Listening on on port 50005
UI theme: light
Font size: large
My Music
Radios
Podcasts
Streaming
Use Apple Remote: yes
Number of paired remotes: 0
Screen saver disabled: no
Max. memory for audio buffers: 13492MB
Local Audio Engine: CoreAudio
Exclusive access: ON
Integer mode: ON
Topping D70 Pro SABRE
Model UID:D70 Pro SABRE:152A:8750
UID:AppleUSBAudioEngine:Topping:D70 Pro SABRE:3142000:1
Active Sample Rate: 768kHz
Selected device:D70 Pro SABRE
Manufacturer: Topping
Model name: Topping D70 Pro SABRE
Model UID: D70 Pro SABRE:152A:8750
UID: AppleUSBAudioEngine:Topping:D70 Pro SABRE:3142000:1
USB Vendor ID: 0x152a
USB Product ID: 0x8750
ID 0x56
Audio buffer frame size : 231 to 4096 frames
Max volume alert: Disabled
DSD via PCM 1.1
Stream ID 0x57 2 channels starting at 1
30 virtual formats:
2 ch Non-mixable linear PCM Interleaved 24 little endian Signed Integer aligned high in 32bit 768kHz
2 ch Non-mixable linear PCM Interleaved 24 little endian Signed Integer aligned high in 32bit 705.6kHz
2 ch Non-mixable linear PCM Interleaved 24 little endian Signed Integer aligned high in 32bit 384kHz
2 ch Non-mixable linear PCM Interleaved 24 little endian Signed Integer aligned high in 32bit 352.8kHz
40 physical formats
2 ch Mixable linear PCM Interleaved 24 little endian Signed Integer aligned high in 32bit 768kHz
2 ch Mixable linear PCM Interleaved 24 little endian Signed Integer aligned high in 32bit 705.6kHz
2 ch Mixable linear PCM Interleaved 24 little endian Signed Integer aligned high in 32bit 384kHz
2 ch Mixable linear PCM Interleaved 24 little endian Signed Integer aligned high in 32bit 352.8kHz
Device #0: ID 0x56 D70 Pro SABRE
Device #1: ID 0x48 MacBook Pro Speakers
Model UID: Speaker
UID: BuiltInSpeakerDevice
Update… I’m not sure why, but my dac just suddenly started to read 11.28 dsd.
I suggest lowering your playback preload memory allocation to 4GB and see how that performs for you… you are currently allocating 13GB of your 16GB System RAM for playback preload buffering…
Hi @daniel8802,
Can you please check your device capabilities using the Audio midi setup app of MacOS?
