Hi there,
I have frequent dropout when playing DSD 256 files on Macbook Pro with Big Sur. DSD128/64 files are ok.
macOS 11.1.0 with 8192MB RAM
Registered to Gankhuyag Adilbish
SoX to DSD256 with filter type B 7th order
Phase = 100
Replay Gain: by track
SW volume control: ON
Sync list: 2 folders
AUTO: /Users/gangar/Downloads/Old /2626-2XHDFT1143-audiophile-analog-collection-vol-1-dsd256-2ch
AUTO: /Volumes/Gangar Home Lacie/Music B/Downloads
iTunes/Music library synchronization: last synchronized on Fri Jan 22 22:32:56 2021
Library database path: /Users/gangar/Library/Application Support/Audirvana/AudirvanaPlusDatabaseV2.sqlite
X-SABRE Pro(MQA)
Model UID:X-SABRE Pro(MQA):20B1:2008
UID:AppleUSBAudioEngine:Matrix Audio:X-SABRE Pro(MQA):14110000:1
ID 0x3b X-SABRE Pro(MQA) Manufacturer:Matrix Audio
Model UID:X-SABRE Pro(MQA):20B1:2008 UID:AppleUSBAudioEngine:Matrix Audio:X-SABRE Pro(MQA):14110000:1
MQA Decoder device
Stream ID 0x3c 2 channels starting at 1
30 virtual formats:
40 physical formats
Device #0: ID 0x31 Built-in Output Manufacturer: Apple Inc. Model UID: AppleHDA:123 UID: AppleHDAEngineOutput:1B,0,1,1:0
Device #1: ID 0x3b X-SABRE Pro(MQA) Manufacturer: Matrix Audio Model UID: X-SABRE Pro(MQA):20B1:2008 UID: AppleUSBAudioEngine:Matrix Audio:X-SABRE Pro(MQA):14110000:1
UPnP devices found : 3
Device #0: ID 0x0 [TV] Samsung 9 Series (55) UID: uuid:a8f1c531-b1f2-4bd7-9ee3-248cfd26cc7d Location: http://192.168.36.223:9197/dmr
Device #1: ID 0x0 SONY XBR-55A8H UID: uuid:23456789-1234-1010-8000-94DB56ACF7EC Location: http://192.168.36.249:52323/MediaRenderer.xml
Device #2: ID 0x0 [TV][LG]55EA970V-ZA UID: uuid:76806af5-bb6a-8068-5ace-c01006f4ea26 Location: http://192.168.36.26:1489/
