hi I should have done th debug with the dac switched on, my bad. see below
Audirvana Studio 2.2.5 (20205)
Windows 10 (19045) with 8GB physical RAM
Connected account of : Daniel Lewis
AUTO: D:\Music
Library database path: C:\Users\danie\AppData\Local\Audirvana\Audirvana\AudirvanaDatabase.sqlite
Listening on 192.168.1.160 on port 50023
Max. memory for audio buffers: 4004MB
Local Audio Engine: ASIO 2
Driver version 1337
Vinshine DENAFRIPS USB DAC
Model UID:Vinshine DENAFRIPS USB DAC
Sample rate switching latency: 1s
Selected device:Vinshine DENAFRIPS USB DAC
Manufacturer:
Model name: Vinshine DENAFRIPS USB DAC
Model UID: Vinshine DENAFRIPS USB DAC
17 available sample rates up to 45158400Hz
1411200
1536000
2822400
5644800
11289600
22579200
45158400
DSD capability: Raw DSD (MSB)
2 ch Integer PCM 32bit little endian 1411.2kHz
2 ch Integer PCM 32bit little endian 1536kHz
2 ch DSD 8bit big endian in 8bit chunk 45158.4kHz
Device #0: Vinshine DENAFRIPS USB DAC
Manufacturer:
Device #1: XMOS USB Audio 2.0 ST 3066
Manufacturer:
Model UID: XMOS USB Audio 2.0 ST 3066
Model name: XMOS USB Audio 2.0 ST 3066
UPnP devices found : 1
Device #0: [TV]UE40D6100
UID: uuid:cfd83c49-69e7-43c4-763d-53eeab9e06ce
Location: http://192.168.1.13:52235/dmr/SamsungMRDesc.xml
Manufacturer: Samsung Electronics
Model name: UE40D6100
