DSD not supported
Hello I’m using YBA A200 amplifier that has a DAC which supports DSD256. However, when I connect my Windows 10 desktop with USB cable it says DSD not supported. Any solutions?
Hello @Marius_Halpern,
Have you installed the USB driver from YBA for your Windows 10 computer?
Yes I have installed the driver from the YBA A200 page.
In Audirvana, have you selected ASIO in the audio output settings?
