DSD over DNLA to Sony
Hi,
New to this platform, so apologies if this has been asked before. JRiver allows for DSD over DNLA, but will not work with my receiver: Sony DN 1080 (apparently 1 line of script will make it work, but I’m not that savvy). Is it possible to send native DSD files via DNLA using Audirvana? Thanks!
Hi. Yes, I send native .dsf files stored in Audirvana via dnla to a Yamaha WXC-50. I had to purchase the WXC-50 because my amp could not decode DSD natively. Your amp however, judging by a quick google, can handle DSD. So I’m not sure why it’s not working.
It does but you’ll need to check the compatibility first.
