Hi team !
Here is my dump log
If I try to play the song, the software emits a tick noise and goes quickly to the end of DSD songs …
Halp !
Best regards
Normand
macOS Version 13.0 (assemblage 22A380) with 16GB physical RAM
Connected account of : Norm
Sync list: 0 folders
iTunes/Music library synchronization: last synchronized on Tue Oct 25 22:05:31 2022
Library database path: /Users/normandhenault/Library/Application Support/Audirvana/AudirvanaDatabase.sqlite
Listening on 127.0.0.1 on port 49613
Local Audio Engine: CoreAudio
Exclusive access: ON
Integer mode: ON
ROTEL ROTEL USB Audio 2.0
Model UID:ROTEL USB Audio 2.0:278B:5100
UID:AppleUSBAudioEngine:ROTEL:ROTEL USB Audio 2.0:110000:1
Device: 2ch Non-mixable linear PCM Interleaved 24bits little endian Signed Integer, 8 bytes per frame 352.8kHz
Active Sample Rate: 352.8kHz
Hog Mode is on
Sample rate limitation: 352.8kHz
Selected device:ROTEL USB Audio 2.0
Manufacturer: ROTEL
Model name: ROTEL USB Audio 2.0
Model UID: ROTEL USB Audio 2.0:278B:5100
UID: AppleUSBAudioEngine:ROTEL:ROTEL USB Audio 2.0:110000:1
USB Vendor ID: 0x278b
USB Product ID: 0x5100
ID 0x72
Audio buffer frame size : 106 to 4096 frames
Stream ID 0x73 2 channels starting at 1
30 virtual formats:
40 physical formats
2 ch Mixable linear PCM Interleaved 16 little endian Signed Integer 768kHz
Device #0: ID 0x72 ROTEL USB Audio 2.0
Manufacturer: ROTEL
Device #1: ID 0x4d Haut-parleurs MacBook Air
Model UID: Speaker
UID: BuiltInSpeakerDevice
Model name: Apple Inc. Haut-parleurs MacBook Air
UPnP devices found : 1
Device #0: ID 0x0 : [TV] Samsung Droite
UID: uuid:4a9510a9-4d3b-443a-b8cf-373fd5f77406
Manufacturer: Samsung Electronics
Model name: UN43TU7000FXZC
