I noticed Dsd tracks skip when I hit the pause and you have to select another album or let it play until the end is there any way to fix that the albums were downloaded from HDTracks so I’m not sure if it’s an issue with the download has anyone else had this problem regards D
Do you have this behavior with any DSD track?
Yes any dsd track I select does it
Do you still have the DSD upsampling in the audio settings of Studio while you have the issue?
Yes ,I raised the buffer rate that seemed to help thought I might need to put more ram in the p.c. because I only have 16 and audervana needs 8 what are your thoughts on that
Have you made test with a lower DSD upsampling like 64 or without upsampling?
Sorry for taking so long to answer Antoine the dac is supposed to handle the higher dsd files its the topping D90se
I did had more ram and that is what helped but this weekend I’ll do another test
