DSD won't stream on ML No, 5101
DSD files won’t stream
Mac OS 14.5 Sonoma
Audirvana Origin
Mac Studio M2 Ultra (Ethernet)
Netwrok player: Mark Levinson No. 5101 (Ethenet)
PCM audio streams successfully from Audirvana
DSD 64 files won’t stream: the audio file seems to be streaming (the clock / timer is advancing), but the sound is just static (no intelligible music, no dropped sounds, no clipping). Just static. I tried adjusting the software volume. No luck.
Debug info:
Audirvana Origin 2.5.13 (20513)
macOS Version 14.5 (Build 23F79) with 64GB physical RAM
Connected account of : Sanjay Verma
AUTO: /Volumes/Glyph 2TB/Music
iTunes/Music library synchronization: last synchronized on Mon Apr 8 17:29:22 2024
Library database path: /Users/sanjayverma/Library/Application Support/Audirvana/AudirvanaDatabase.sqlite
Listening on 127.0.0.1 on port 49794
Font size: regular
My Music
Library
Use Apple Remote: yes
Number of paired remotes: 1
Screen saver disabled: no
Active method: UPnP
Preferred device: [UPnP] No5101 Model UID:Mark Levinson No5101 UID:uuid:140479c0-58f3-1cef-84bf-001b7c05a816
Currently playing to UPnP device at 24 bits 176.4kHz
Selected device:No5101
Manufacturer: Mark Levinson
Model name: No5101
Model UID: Mark Levinson No5101
UID: uuid:140479c0-58f3-1cef-84bf-001b7c05a816
UPnP device at http://192.168.7.109:2870/dmr.xml
ID 0x0
Volume control: Yes
Max volume alert: Disabled
DSD via PCM 1.0
UPnP set capabilities
Maximum PCM bitdepth set: 24
Not native DSD capable
Avoid RAW PCM streams: Yes
http-get::image/jpeg:DLNA.ORG_PN=JPEG_SM
http-get:
:image/png:DLNA.ORG_PN=PNG_LRG
http-get::image/jpeg:DLNA.ORG_PN=JPEG_MED
http-get:
:image/jpeg:DLNA.ORG_PN=JPEG_LRG
http-get:
:audio/L16;rate=44100;channels=1:DLNA.ORG_PN=LPCM
http-get:
:audio/L16;rate=48000;channels=1:DLNA.ORG_PN=LPCM
http-get:
:audio/x-ms-wma:DLNA.ORG_PN=WMABASE
http-get:
:audio/mpeg:DLNA.ORG_PN=MP3
http-get:
:audio/mp4:DLNA.ORG_PN=AAC_ISO_320
http-get:
:video/mpeg:DLNA.ORG_PN=MPEG_PS_PAL
http-get::video/mpeg:DLNA.ORG_PN=MPEG_TS_SD_NA_ISO
http-get:
:video/mpeg:DLNA.ORG_PN=MPEG_TS_HD_NA_ISO
http-get::video/mpeg:DLNA.ORG_PN=MPEG_TS_SD_EU_ISO
http-get:
:video/mpeg:DLNA.ORG_PN=MPEG_TS_HD_KO_ISO
http-get::video/mpeg:DLNA.ORG_PN=MPEG_TS_SD_KO_ISO
http-get:
:video/mpeg:DLNA.ORG_PN=MPEG_PS_NTSC
http-get::video/mpeg:DLNA.ORG_PN=MPEG_PS_NTSC_XAC3
http-get:
:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_JP_T
http-get::video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_HD_NA_T
http-get:
:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_NA_T
http-get::video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_KO_T
http-get:
:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_EU_T
http-get::video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_HD_KO_T
http-get:
http-get:
http-get::video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_EU
http-get:
http-get::video/mp4:DLNA.ORG_PN=AVC_MP4_BL_CIF15_AAC_520
http-get:
:video/x-ms-wmv:DLNA.ORG_PN=WMVHIGH_FULL
http-get::video/x-ms-wmv:DLNA.ORG_PN=WMVMED_FULL
http-get:
:video/x-ms-wmv:DLNA.ORG_PN=WMVMED_BASE
http-get::image/vnd.ms-photo:
http-get::image/gif:
http-get::image/x-ycbcr-yuv420:
http-get::image/png:
http-get::image/mpo:
http-get::image/x-icon:
http-get::image/x-quicktime:
http-get::image/jpe:
http-get::audio/L8:
http-get::audio/mp1:
http-get::audio/mp2:
http-get::audio/basic:
http-get::audio/aiff:
http-get::audio/mid:
http-get::audio/x-ms-wax:
http-get::audio/wav:
http-get::audio/vnd.rn-realaudio:
http-get::audio/x-mpegurl:
http-get::audio/x-wav:
http-get::audio/x-flac:
http-get::audio/mp4:
http-get::audio/x-m4a:
http-get::audio/x-ms-wmv:
http-get::audio/x-ogg:
http-get::audio/midi:
http-get::audio/x-aac:
http-get::audio/x-ac3:
http-get::audio/x-atrac3:
http-get::audio/x-dts:
http-get::audio/x-pn-realaudio:
http-get::audio/x-quicktime:
http-get::audio/dolby:
http-get::audio/adts:
http-get::audio/3gpp:
http-get::audio/sonyoma:
http-get::video/3gpp:
http-get::video/mp2p:
http-get::video/mpeg2:
http-get::video/quicktime:
http-get::video/x-dv:
http-get::video/x-motion-jpeg:
http-get::video/x-nerodigital-ps:
http-get::video/mp1s:
http-get::video/tts:
http-get::video/x-msvideo:
http-get::video/divx:
http-get::video/xiid:
http-get::video/asf:
http-get::video/wmv:
http-get::video/x-matroska:
http-get::video/rtml:
http-get::video/x-ms-wmx:
http-get::video/x-ms-wm:
http-get::video/x-ms-asf:
http-get::video/x-ms-wvx:
http-get::video/x-ms-dvr:
http-get::video/avi:
http-get::video/vnd.rn-realvideo:
http-get::video/x-pn-realmedia:
DLNA 1.5: Yes
Native Gapless playback: No
Missing events workaround: No
Can play native DSD: No
Volume Control: scalar
12 virtual formats:
0 physical formats
NrTracks: 1
MediaDuration: 0:19:44.000
CurrentURI: http://192.168.7.122:49152/audirvana/audio_f_1.wav
CurrentURIMetadata:
dc:titlePiano Concerto no. 3 - Allegro ma non Tanto</dc:title>
dc:creatorModestas Pitrenas</dc:creator>
upnp:artistModestas Pitrenas</upnp:artist>
<upnp:author role=“Composer”>Rachmaninoff</upnp:author>
upnp:genreClassical</upnp:genre>
upnp:albumArtURIhttp://192.168.7.122:49152/audirvana/artwork_1_1.jpg</upnp:albumArtURI>
upnp:albumRachmaninoff Piano Concerto no. 3</upnp:album>
nextURI: NOT_IMPLEMENTED
PlayMedium: NETWORK
Current transport actions:
Play,Stop,Pause,Seek,X_DLNA_SeekTime
<?xml version="1.0"?> 1 0 DMR-1.50 urn:schemas-upnp-org:device:MediaRenderer:1 No5101 Mark Levinson http://www.marklevinson.com/ CD Player No5101 1.0 http://www.marklevinson.com/ uuid:140479c0-58f3-1cef-84bf-001b7c05a816 image/png 48 48 24 /icon/DMR-small.png image/png 120 120 24 /icon/DMR-large.png image/jpeg 48 48 24 /icon/DMR-small.jpg image/jpeg 120 120 24 /icon/DMR-large.jpg urn:schemas-upnp-org:service:RenderingControl:1 urn:upnp-org:serviceId:RenderingControl /dmr_rcs.xml control/RenderingControl event/RenderingControl urn:schemas-upnp-org:service:ConnectionManager:1 urn:upnp-org:serviceId:ConnectionManager /dmr_cms.xml control/ConnectionManager event/ConnectionManager urn:schemas-upnp-org:service:AVTransport:1 urn:upnp-org:serviceId:AVTransport /dmr_avts.xml control/AVTransport event/AVTransport
UPnP devices found : 5
Device #0: ID 0x0 : [TV] Samsung 7 Series (58)
UID: uuid:556bb8e1-9d7d-4f7e-aa95-df9610ea5236
Manufacturer: Samsung Electronics
Model name: UN58RU710DFXZA
Device #1: ID 0x0 : OPPO UDP-205
UID: uuid:d5a8547e-1dd1-11b2-b63f-88f283b14eb6
Manufacturer: OPPO
Model name: OPPO UDP-205
Device #2: ID 0x0 : [LG] webOS TV OLED65C2AUA
UID: uuid:70053af5-edbd-7468-545c-95dca5d655cc
Manufacturer: LG Electronics.
Model name: LG TV
Device #3: ID 0x0 : Chord 2Go:Chord2Go
UID: uuid:063379e0-de67-d8d6-0340-00602f0bda73
Location: http://192.168.7.101:49152/uuid-063379e0-de67-d8d6-0340-00602f0bda73/description.xml
Manufacturer: Chord Electronics
Model name: 2Go
Device #4: ID 0x0 : No5101
Model name: No5101
Max. memory for audio buffers: 1430MB
Local Audio Engine: CoreAudio
Local devices found : 3
Device #0: ID 0x32 Studio Display Speakers
Model UID: Studio Display Audio Control:05AC:1114
UID: AppleUSBAudioEngine:Apple Inc.:Studio Display:00008030-001C616A0E04802E:8,9
USB Vendor ID: 0x05ac
USB Product ID: 0x1114
Model name: Apple Inc. Studio Display Speakers
Device #1: ID 0x53 Mac Studio Speakers
Model UID: Speaker
UID: BuiltInSpeakerDevice
Model name: Apple Inc. Mac Studio Speakers
Device #2: ID 0x59 Parallels Access Sound
Manufacturer: Parallels
Model UID: com.parallels.access.audio.virtual-speaker.model
Model name: Parallels Access Sound
The UPnP / DNLA supported protocols for this device, does not include raw DSD file support… Have you enabled DoP and tried sending the files this way? It looks like the maximum DSD sample-rate this device will play is 2.8MHz (DSD64) via DoP… 176.4kHz is the PCM carrier sample-rate for DSD64 via DoP (DSD over PCM)
Make sure you have the latest firmware installed…
There is some confusing information on the site regarding DSD format support…
According to the specs (here the user guide) it can play only PCM
I agree the information is conflicting. At the end of the same Quick Start Guide (from which you provided that screen print) is this (see my pic). It does seem to support files up to DSD 128. But I have been able to successfully stream DSD.
Thank you. Yes, I am using DoP (tried both 1.0 and 1.1). No success.
I will check with dealer tech support about firmware upgrade and try manufacturer tech support. Agree the information provided regarding DSD file support is conflicting. Thank you.
With DoP enabled… change ‘For bridge devices connected to a DAC’ to ‘No Limit’
and disable ‘Auto-detect MQA devices’
Can you play DSD64 files via the USB bus, with DoP enabled?
Look at the debug report regarding ‘UPnP / DLNA supported protocols :’ You will not see DSD support… and again you will see under 'DLNA 1.5: Yes’ the report shows ‘Can play native DSD: No’.
Thank you very much. Will try that after work and update you on results.
ML No. 5101 player does not have USB-B for direct connect to laptop / computer. Therefore I am unable to test DoP via USB from Audirvana.
5101 only has USB-A (for use with thumb drive). I have not yet tried USB-A with audio files of any type.
The ESS Pro DAC is PCM-centric and does not provide an unfettered 1-bit PDM signal path to output for DSD… You will never get a pure DSD signal output from this device… I suspect the USB port is where you can play DSD files via an attached storage device… In this case, it would make sense that the system can play DSD128 files as these are converted to multi-bit DSD for output by virtue of this connection to the DAC chipset.
You are correct.
Response for dealer tech support:
“The 5101 doesn’t support DSD via streaming, only via USB or SACD. Secondly, we would really recommend you check what software you’re on and if you’re not on the latest (v19) then please update.”
That’s helpful to know. Appreciate the extra insights.
So, even the SACD on the 5101 is not pure DSD?
That’s disappointing. Glad it comes with 60 day money back guarantee.
In all ESS chipsets the 1-bit PDM (DSD) is converted to multi-bit PCM (DSD-Wide) for output to the D/A circuitry… Technically, all PCM signals handled by ESS chipsets are converted to multi-bit DSD-Wide for D/A conversion.
So it seems custom FPGA (e.g., Chord, PS Audio, DCS Ring DAC) would be able to handle DSD more purely. Or a DAC with dedicated DSD processing (T+A?).
Thanks for the insight.
Chord is PCM-centric…
I believe dCS has a pure 1-bit signal path to output… and T+A has a pure 1-bit path…
This is what you were looking for…
Well, the lesson learned is that one should read what is written and not what he would like to read
these are specific specs for the described input
and these are general specs and they are right as the device is a SACD player
therefore there isn’t any ambiguity
Stefano_mbp: I appreciate the detailed demonstration. However, I don’t appreciate the sarcastic tone. I have read specs for MANY DAC’s and they are all much more clear about the file formats and resolution supported by each input source (e.g., different resolution supported by digital optical, coax, USB, network, etc.).
What you demonstrated above still does NOT clarify what tech support informed me: DSD files are only supported by USB-A flash drive on this device. So, despite your condescending tone, it is absolutely ambiguous (no where in the documentation does it clearly stipulate that DSD is only via USB-A flash drive).
Anyway, thanks for your time.
Agoldnear: Thank you for that information. That device is $25k!
Hi @sanjay1297,
You are right; I have seen numerous brands needing clarity on this subject while scrolling on their product page. It’s hard to do things simple :grimacing:
I’m sorry you can’t stream in DSD to your device, nonetheless.
Hi @sanjay1297 ,
Here is an interesting discussion about DACs able to play DSD natively.
Link: Best HQplayer DSD only DACs - Audio Gear Talk / HQ Player
It is a long thread, but it boils down to the fact that there are more affordable DACs capable of direct DSD as well. A number of DACS with an AKM chip are capable to play DSD without resampling to pcm for instance (when they have the option in the settings to play DSD directly), but there are also other (R2R) solutions (Holo Audio Cyan 2 and others).
The link is HQPlayer centered but gives a lot of information. Various brands and types are measured and mentioned. Hopefully this info is useful to you to find a DAC that suits your needs.
It does not have to cost an arm and a leg. The HOLO Audio Cyan 2 is around $1400, and the Topping DX9 with AKM chip (and direct DSD mode) is around 1300 euro’s. But there are more options if you read the thread.
HoloAudio – Cyan 2 DAC (NOS - R2R – DSD1024) • Magna Hifi
TOPPING DX9 DAC AK4499EQ Headphone Amplifier NFCA Bluetooth 5.1 AptX LDAC 32bit 768kHz DSD512 Black - Audiophonics
Another option–
The DirectStream DAC MK2 converts all PCM signals to 1-Bit DSD…
A review of the Mt. Massive software update-
