Hello,
Try this to start new.
Big text, but fast doing it…
If you have Playlists that are important export them first to desktop and save them in a folder… when Audirvana is reset, you can re-import them back in one shot. sadly to this day, the folders they were in if so, are not back, you have to do them again…
Before doing this, maybe you should not connect after deleting those files to Roon, Tidal or others… Install Audirvana alone with your database… if working, log to Roon or else after.
Delete your music folder(s) in your Audirvana preferences window with minus sign…
Close Audirvana.
Trash All the files in that folder (that is your database of music, back it up! or not).
Restart MAC.
Open Audirvana, choose a library music folder and LET IT GO, even better don’t try to adjust windows or edit files, even playing music while it is not finished… you’ll see the progress bar going… Could be long the first time depending on how large your library is, and MAC is fast or not… go to sleep if it is too long ! Then when sync is finished, shut down Audirvana, yes, close it before playing a song… that way, you will have your database new from scratch saved without crashing or with doubles.
Then copy the .sqlite file to somewhere else from that folder…
as a backup in a folder like dated as today, then open Audirvana.
Like that, if you enter a bug you can always close Audirvana, put the latest perfect backup .sqlite in the same folder, and restart mac, then Audirvana… you’ll be at that latest backup… if you have put something else there or edit songs in between, it will sync the new files, but you will only lose your play counts of those files played in between backups.
