Here you go
Audirvana Mac Version 3.5.29 (3559)
macOS 10.15.3 with 8192MB RAM
AUTO: /Users/janschotte/Music/Music Library
Library database path: /Users/janschotte/Library/Application Support/Audirvana/AudirvanaPlusDatabaseV2.sqlite
Preferred device: H190_Living Model UID:Hegel H190_Living UID:uuid:225cf2b8-1dd2-11b2-847e-532404d667bc
UPnP device at http://192.168.0.171:38400/description.xml
ID 0x0 H190_Living Manufacturer:Hegel
Volume control: No
http-get::audio/flac:
http-get::audio/x-flac:
http-get::audio/wav:
http-get::audio/x-wav:
http-get::application/ogg:
DLNA 1.5: Yes
Gapless playback: Yes
Missing events workaround: No
Can play native DSD: No
12 virtual formats:
0 physical formats
NrTracks: 0
MediaDuration: 0:03:06.000
CurrentURI:
CurrentURIMetadata:
nextURI:
nextURIMetadata:
PlayMedium: NONE
<?xml version="1.0"?>
1
0
SetAVTransportURI
InstanceID
in
A_ARG_TYPE_InstanceID
CurrentURI
in
AVTransportURI
CurrentURIMetaData
in
AVTransportURIMetaData
GetMediaInfo
InstanceID
in
NrTracks
out
NumberOfTracks
MediaDuration
out
CurrentMediaDuration
CurrentURI
out
AVTransportURI
CurrentURIMetaData
out
NextURI
out
NextAVTransportURI
NextURIMetaData
out
NextAVTransportURIMetaData
PlayMedium
out
PlaybackStorageMedium
RecordMedium
out
RecordStorageMedium
WriteStatus
out
RecordMediumWriteStatus
GetTransportInfo
InstanceID
in
out
TransportState
out
TransportStatus
CurrentSpeed
out
TransportPlaySpeed
GetPositionInfo
InstanceID
in
Track
out
CurrentTrack
TrackDuration
out
CurrentTrackDuration
TrackMetaData
out
CurrentTrackMetaData
TrackURI
out
CurrentTrackURI
RelTime
out
RelativeTimePosition
AbsTime
out
AbsoluteTimePosition
RelCount
out
RelativeCounterPosition
AbsCount
out
AbsoluteCounterPosition
GetDeviceCapabilities
InstanceID
in
PlayMedia
out
PossiblePlaybackStorageMedia
RecMedia
out
PossibleRecordStorageMedia
RecQualityModes
out
PossibleRecordQualityModes
GetTransportSettings
InstanceID
in
PlayMode
out
CurrentPlayMode
RecQualityMode
out
CurrentRecordQualityMode
SetPlayMode
InstanceID
in
NewPlayMode
in
CurrentPlayMode
Stop
InstanceID
in
Play
InstanceID
in
Speed
in
TransportPlaySpeed
Pause
InstanceID
in
Seek
InstanceID
in
Unit
in
A_ARG_TYPE_SeekMode
Target
in
A_ARG_TYPE_SeekTarget
Next
InstanceID
in
Previous
InstanceID
in
GetCurrentTransportActions
InstanceID
in
Actions
out
TransportState
string
STOPPED
PAUSED_PLAYBACK
PLAYING
TRANSITIONING
NO_MEDIA_PRESENT
TransportStatus
string
OK
ERROR_OCCURRED
string
UNKNOWN
CD-DA
DVD-VIDEO
HDD
NONE
RecordStorageMedium
string
NOT_IMPLEMENTED
string
UNKNOWN
CD-DA
DVD-VIDEO
HDD
string
NOT_IMPLEMENTED
CurrentPlayMode
string
NORMAL
SHUFFLE
REPEAT_ONE
REPEAT_TRACK
REPEAT_ALL
NORMAL
TransportPlaySpeed
string
1
string
NOT_IMPLEMENTED
string
NOT_IMPLEMENTED
string
NOT_IMPLEMENTED
NumberOfTracks
ui4
0
1
CurrentTrack
ui4
0
1
1
string
string
string
CurrentTrackURI
string
AVTransportURI
string
string
NextAVTransportURI
string
string
string
string
i4
i4
string
LastChange
string
A_ARG_TYPE_SeekMode
string
ABS_COUNT
TRACK_NR
REL_TIME
string
ui4
1
0
DMR-1.50
QPlay:2
H190_Living
Hegel
http://www.hegel.com
H190
H190
1.0
/RenderingControl.xml
/RenderingControl
/RenderingControl/eventSub
/AVTransport.xml
/AVTransport
/AVTransport/eventSub
/ConnectionManager.xml
/ConnectionManager
/ConnectionManager/eventSub
urn:schemas-tencent-com:service:QPlay:1
urn:tencent-com:serviceId:QPlay
/QPlay.xml
/QPlay
/QPlay/eventSub
UPnP devices found : 3
Device #0: ID 0x0 H190_Living UID: uuid:225cf2b8-1dd2-11b2-847e-532404d667bc Location: http://192.168.0.171:38400/description.xml
Device #1: ID 0x0 Keuken UID: uuid:6245175b-82bd-40f6-b133-5a9c75a19ad1 Location: http://192.168.0.15:34654/6245175b-82bd-40f6-b133-5a9c75a19ad1.xml
Device #2: ID 0x0 UID: uuid:7c4a3491-7139-42ed-9209-61d88eae9e68 Location: http://192.168.0.30:50231/7c4a3491-7139-42ed-9209-61d88eae9e68.xml
Max. memory for audio buffers: 5460MB
Device #0: ID 0x2e Built-in Output Manufacturer: Apple Inc. Model UID: AppleHDA:130 UID: AppleHDAEngineOutput:1F,3,0,1,2:0
