Hello,
Starting yesterday, I am getting " Error logging onto Qobuz" message. I can logon to Qobuz site and my subscription is valid. Please help! Debug info. below.
Thank you!
Isaku
Audirvana Mac Version 3.5.35 (3565)
macOS 10.11.6 with 8192MB RAM
Registered to Isaku Higa
Per track: OFF
iZotope SRC not in use iZotope SRC filter parameters
Steepness = 150
Filter max length = 500000
Cut-Off (x Nyquist) = 100%
Anti-aliasing = 200
Phase = 100%
Sync list: 4 folders
Manual: (OFFLINE) /Volumes/SSD1Music/Classical
Manual: (OFFLINE) /Volumes/SSD1Music/Jazz
Manual: (OFFLINE) /Volumes/SSD1Music/Others
Manual: (OFFLINE) /Volumes/SSD1Music/RockPop
Library database path: /Users/TheHigaFamilyMIni/Library/Application Support/Audirvana/AudirvanaPlusDatabaseV2.sqlite
Qobuz: Login failed
Max. memory for audio buffers: 3838MB
Weiss Firewire IO
Model UID:WeissFirewire:DICE Device
UID:WeissFirewireAudioEngine:0
ID 0x26 Weiss Firewire IO Manufacturer:Weiss Engineering Ltd.
Model UID:WeissFirewire:DICE Device UID:WeissFirewireAudioEngine:0
Stream ID 0x27 2 channels starting at 1
6 virtual formats:
6 physical formats
2 ch Mixable linear PCM Interleaved 24 big endian Signed Integer 192kHz
2 ch Mixable linear PCM Interleaved 24 big endian Signed Integer 176.4kHz
2 ch Mixable linear PCM Interleaved 24 big endian Signed Integer 96kHz
2 ch Mixable linear PCM Interleaved 24 big endian Signed Integer 88.2kHz
2 ch Mixable linear PCM Interleaved 24 big endian Signed Integer 48kHz
2 ch Mixable linear PCM Interleaved 24 big endian Signed Integer 44.1kHz
Local devices found : 3
Device #0: ID 0x3d Built-in Output Manufacturer: Apple Inc. Model UID: AppleHDA:3 UID: AppleHDAEngineOutput:8,0,1,2:0
Device #1: ID 0x4a HDMI Manufacturer: Apple Inc. Model UID: AppleHDA:3 UID: AppleHDAEngineOutputDP:8,5,1,0:0:{A934-A296-01010101}
Device #2: ID 0x26 Weiss Firewire IO Manufacturer: Weiss Engineering Ltd. Model UID: WeissFirewire:DICE Device UID: WeissFirewireAudioEngine:0
UPnP devices found : 1
Device #0: ID 0x0 50DX780_Series UID: uuid:4D454930-0100-1000-8001-D8AFF148AA2F Location: http://192.168.0.18:55000/dmr/ddd.xml
