Maybe is not an error. As I know from last year when I used Tidal this service has also video content wich can be played with their native apps, Audirvana plays only audio wich is poor quality for these files.
Roon and mconnect play this CD correct
Why are the files lossy? And even 96kbps?
Edit:
Or is that because this is the audio stream of a video file?
Hello @e1mrba,
Here is what I see on my side:
Please remove the line corresponding to your logged-in account to avoid displaying your email address and first name/last name publicly.
Audirvana Studio 1.8.5 (10805)
Windows 10 (19043) with 32GB physical RAM
Connected account: xxx
VST3 plugin #0: C:\Program Files\Common Files\VST3\MeldaProduction\Tools\MAnalyzer.vst3
ClassID: 4D656C646170726F4D4165624D416562
VST3 plugin #1: C:\Program Files\Common Files\VST3\MeldaProduction\Tools\MUtility.vst3
ClassID: 4D656C646170726F4D7574694D757469
VST3 plugin #2: C:\Program Files\Common Files\VST3\MeldaProduction\Filter\MBandPass.vst3
ClassID: 4D656C646170726F4D4261404D426140
VST3 plugin #3: C:\Program Files\Common Files\VST3\DiracLiveProcessor.vst3
ClassID: 56535456376C6564697261636C697665
Bandwidth at 0dB = 99.0516%
Anti-aliasing = 99.1429
Phase = 25%
SW volume control: ON
Sync list: 3 folders
AUTO: E:\sync\TestMusic
AUTO: \NETHD2\music\1MR
AUTO: \NETHD2\music\testcd
Library database path: E:\sync\audirvana\studio\AudirvanaDatabase.sqlite
Listening on 192.168.x.x on port 54991
HRA-Streaming: Connected as SUBSCRIPTION
Max. memory for audio buffers: 12416MB
Local Audio Engine: ASIO ASIO 2 driver version 535
XMOS USB Audio 2.0 ST 3017
Model UID:XMOS USB Audio 2.0 ST 3017
Device: 2ch 32bits Integer, 8 bytes per frame 192kHz
Active Sample Rate: 192kHz
Manufacturer:
Model Name: XMOS USB Audio 2.0 ST 3017
Model UID: XMOS USB Audio 2.0 ST 3017
Local devices found : 6
Device #0: ASIO 2.2 - AUDIOPROBE SPARTAN A Manufacturer: Model UID: ASIO 2.2 - AUDIOPROBE SPARTAN A UID: ASIO 2.2 - AUDIOPROBE SPARTAN A Model Name: ASIO 2.2 - AUDIOPROBE SPARTAN A
Device #1: ASIO4ALL v2 Manufacturer: Model UID: ASIO4ALL v2 UID: ASIO4ALL v2 Model Name: ASIO4ALL v2
Device #2: FlexASIO Manufacturer: Model UID: FlexASIO UID: FlexASIO Model Name: FlexASIO
Device #3: M-Audio USB ASIO Manufacturer: Model UID: M-Audio USB ASIO UID: M-Audio USB ASIO Model Name: M-Audio USB ASIO
Device #4: miniDSP ASIO Driver Manufacturer: Model UID: miniDSP ASIO Driver UID: miniDSP ASIO Driver Model Name: miniDSP ASIO Driver
Device #5: XMOS USB Audio 2.0 ST 3017 Manufacturer: Model UID: XMOS USB Audio 2.0 ST 3017 UID: XMOS USB Audio 2.0 ST 3017 Model Name: XMOS USB Audio 2.0 ST 3017
Have you tried to disconnect and reconnect your Tidal account?
Install Tidal app. It’s a good idea to have Tidal/Qobuz apps installed even for debugging purposes, to check with them. Are you sure is not an audio album that contains a video file? Check that file with Tidal app, I think is the best test. Before subscribing to Audirvana I made some playlists in the Tidal mobile app with mixed content (audio/video). Audirvana plays video files as audio and shows like in your picture.
Understand. Sorry I didn’t help you.
I found an post from 2018 mentioning Audirvana does not support AAC+.
AAC is no problem.
Could this be something?
What ever the problem may be 96kbps is not anywhere near acceptable for a paid service.
Probably not when he recognized Antoine correctly.
I can confrm just for mp3 codec. Here is the link:
https://codecguide.com/download_k-lite_codec_pack_full.htm
It is a good idea to have installed even if don’t solve the problem. Along with VLC and AS are the only players that I use. And Qobuz app. And iTunes just rarely for an old iPod and also for codecs. Never WMP.
I tried both lossless and master
It seems that if you fill out this survey you can indicate that an album is not available in the desired quality.
https://www.surveygizmo.com/s3/1888513/TIDAL-Music-Request
On Qobuz it is available in cd quality.
Does this album is the only one in this case or all of the album you see in Tidal have the same behavior?
