All of a sudden Studio started throwing this error. I searched on the forum and based upon that, I disabled upsampling Also disabled Sys Optimizer, no mas.
This started happening after I added Qobuz trial acct. Later I removed that Quobuz, still issue persists.
Error happens even on Radio(Streaming)
Audirvana Studio 2.2.3 (20203)
macOS 12.6.2 with 8GB physical RAM
Connected account of : XYZ
Sync list: 0 folders
iTunes/Music library synchronization: last synchronized on Mon Jan 16 08:51:04 2023
Library database path: /Users/xyz/Library/Application Support/Audirvana/AudirvanaDatabase.sqlite
Listening on fe80::479:d3b0:6778:63e8%en0 on port 50161
Active method: UPnP
Preferred device: HEGEL HEGEL Model UID:Hegel H120 UID:uuid:1a910c04-1dd2-11b2-86ab-bfb10a2102dd
Selected device:Hegel
Manufacturer: Hegel
Model name: H120
Model UID: Hegel H120
UID: uuid:1a910c04-1dd2-11b2-86ab-bfb10a2102dd
UPnP device at http://192.168.68.116:38400/description.xml
ID 0x0
Volume control: Yes
UPnP set capabilities
Maximum PCM bitdepth set: 24
Not native DSD capable
Avoid RAW PCM streams: No
http-get::audio/l16;rate=44100;channels=1:dlna.org_pn=lpcm
http-get::audio/l16;rate=44100;channels=2:dlna.org_pn=lpcm
http-get::audio/l16;rate=48000;channels=1:dlna.org_pn=lpcm
http-get::audio/l16;rate=48000;channels=2:dlna.org_pn=lpcm
http-get::audio/mpeg:dlna.org_pn=mp3
http-get::audio/x-ms-wma:dlna.org_pn=wmabase
http-get::audio/x-ms-wma:dlna.org_pn=wmafull
http-get::audio/x-ms-wma:dlna.org_pn=wmapro
http-get::audio/mp4:dlna.org_pn=aac_iso
http-get::audio/3gpp:dlna.org_pn=aac_iso
http-get::audio/mp4:dlna.org_pn=aac_iso_320
http-get::audio/3gpp:dlna.org_pn=aac_iso_320
http-get::audio/vnd.dlna.adts:dlna.org_pn=aac_adts
http-get::audio/vnd.dlna.adts:dlna.org_pn=aac_adts_320
http-get::audio/flac:
http-get::audio/x-flac:
http-get::audio/wav:
http-get::audio/x-wav:
http-get::application/ogg:
DLNA 1.5: Yes
Native Gapless playback: Yes
Missing events workaround: No
Can play native DSD: No
Volume Control: dB
14 virtual formats:
2 ch Non-mixable linear PCM Interleaved 16 big endian Signed Integer 44.1kHz
2 ch Non-mixable linear PCM Interleaved 16 big endian Signed Integer 48kHz
0 physical formats
NrTracks: 1
MediaDuration: 0:05:58.000
CurrentURI: http://192.168.68.104:49152/audirvana/audioTest.pcm
CurrentURIMetadata:
dc:titletestTitle</dc:title>
nextURI:
nextURIMetadata:
PlayMedium: NONE
Current transport actions:
Play
<?xml version="1.0"?> 1 0 DMR-1.50 urn:schemas-upnp-org:device:MediaRenderer:1 Hegel Hegel http://www.hegel.com H120 H120 1.0 http://www.hegel.com uuid:1a910c04-1dd2-11b2-86ab-bfb10a2102dd http://192.168.68.116 urn:schemas-upnp-org:service:RenderingControl:1 urn:upnp-org:serviceId:RenderingControl /RenderingControl.xml /RenderingControl /RenderingControl/eventSub urn:schemas-upnp-org:service:AVTransport:1 urn:upnp-org:serviceId:AVTransport /AVTransport.xml /AVTransport /AVTransport/eventSub urn:schemas-upnp-org:service:ConnectionManager:1 urn:upnp-org:serviceId:ConnectionManager /ConnectionManager.xml /ConnectionManager /ConnectionManager/eventSub http://192.168.68.116:38400Current device RootDevice description:
<?xml version="1.0"?> 1 0 DMR-1.50 urn:schemas-upnp-org:device:MediaRenderer:1 Hegel Hegel http://www.hegel.com H120 H120 1.0 http://www.hegel.com uuid:1a910c04-1dd2-11b2-86ab-bfb10a2102dd http://192.168.68.116 urn:schemas-upnp-org:service:RenderingControl:1 urn:upnp-org:serviceId:RenderingControl /RenderingControl.xml /RenderingControl /RenderingControl/eventSub urn:schemas-upnp-org:service:AVTransport:1 urn:upnp-org:serviceId:AVTransport /AVTransport.xml /AVTransport /AVTransport/eventSub urn:schemas-upnp-org:service:ConnectionManager:1 urn:upnp-org:serviceId:ConnectionManager /ConnectionManager.xml /ConnectionManager /ConnectionManager/eventSub http://192.168.68.116:38400UPnP devices found : 2
Device #0: ID 0x0 : HomePod
UID: uuid:c4f49284-1db6-134b-0080-0005cd88b467
Location: http://192.168.68.106:60006/upnp/desc/aios_device/aios_device.xml
Manufacturer: Denon
Model name: Denon DHT-S516H
Device #1: ID 0x0 : Hegel
Manufacturer: Hegel
Model name: H120
Max. memory for audio buffers: 4346MB
Local Audio Engine: CoreAudio
Device #0: ID 0x31 Built-in Output
Model UID: AppleHDA:123
