Was not working. Removed it. Installed. Ok on PC, moved to USB to DAC, fine for a few minutes. Locked again. Error starting device playback, ASIO, no volume bar on app.
Hello @jeanft,
Can you send me a copy of the “Debug Info” while you have selected your DAC? You can get it in Audirvana Settings>General>Debug Info
Bonsoir Damien,
Seems to be working now. Strange. Sometimes it’s all grey and I can’t modify anything when I go to
Combo 384/Asio 1.03. Had issues with the keyboard as well, stopping music when it 's supposed to be turned off.
Audirvana 3.5.42
SoX with 2x upsampling
SW volume control: ON
Sync list: 0 folders
Library database path: C:\Users\jeanf\AppData\Local\Audirvana\AudirvanaPlus\AudirvanaPlusDatabaseV2.sqlite
Max. memory for audio buffers: 5074MB
Local Audio Engine:ASIO 2 driver version 2
ASIO4ALL v2
Model UID:ASIO4ALL v2
UID:ASIO4ALL v2
Device: 16ch 32bits Integer, 64 bytes per frame 88.2kHz
Active Sample Rate: 88.2kHz
Combo384 ASIO 1.03 Manufacturer:
Model UID:Combo384 ASIO 1.03 UID:Combo384 ASIO 1.03
17 available sample rates up to 45158400Hz
1411200
1536000
2822400
5644800
11289600
22579200
45158400
DSD capability: Raw DSD (MSB)
Multichannel: 16 channels
Channel 2 mapped to 2
Channel 3 mapped to 3
Channel 4 mapped to 4
Channel 5 mapped to 5
Channel 6 mapped to 6
Channel 7 mapped to 7
Channel 8 mapped to 8
Channel 9 mapped to 9
Channel 10 mapped to 10
Channel 11 mapped to 11
Channel 12 mapped to 12
Channel 13 mapped to 13
Channel 14 mapped to 14
Channel 15 mapped to 15
Number of channels: 16
Simple stereo device: No
16 ch Integer PCM 32bit little endian 44.1kHz
16 ch Integer PCM 32bit little endian 48kHz
16 ch Integer PCM 32bit little endian 88.2kHz
16 ch Integer PCM 32bit little endian 96kHz
16 ch Integer PCM 32bit little endian 176.4kHz
16 ch Integer PCM 32bit little endian 192kHz
16 ch Integer PCM 32bit little endian 352.8kHz
16 ch Integer PCM 32bit little endian 384kHz
16 ch Integer PCM 32bit little endian 705.6kHz
16 ch Integer PCM 32bit little endian 768kHz
16 ch Integer PCM 32bit little endian 1411.2kHz
16 ch Integer PCM 32bit little endian 1536kHz
16 ch DSD 8bit big endian in 8bit chunk 2822.4kHz
16 ch DSD 8bit big endian in 8bit chunk 5644.8kHz
16 ch DSD 8bit big endian in 8bit chunk 11289.6kHz
16 ch DSD 8bit big endian in 8bit chunk 22579.2kHz
16 ch DSD 8bit big endian in 8bit chunk 45158.4kHz
Device #0: Combo384 ASIO 1.03 Manufacturer: Model UID: Combo384 ASIO 1.03 UID: Combo384 ASIO 1.03
Merci,
Cordialement,
JF T
