Hi, yes. here it is:
BTW: There is an option “limit to24bits” mentioned in the file. But I can not find where I could adjust that in the SW UI. My DAC can just support 24 bits. I wonder always that Audirvana shows me 32bit resolution while playback. It this something to worry? (Wrong dither settings?)
Regards
Sebastian
Audirvana 3.5.43
Phase = 28
SW volume control: ON
AUTO: D:\Musik
Library database path: C:\Users\arfi\AppData\Local\Audirvana\AudirvanaPlus\AudirvanaPlusDatabaseV2.sqlite
Max. memory for audio buffers: 5510MB
Local Audio Engine:ASIO 2 driver version 802
XMOS USB Audio 2.0 ST 2023
Model UID:XMOS USB Audio 2.0 ST 2023
Sample rate switching latency: 5s
XMOS USB Audio 2.0 ST 2023 Manufacturer:
Model UID:XMOS USB Audio 2.0 ST 2023 UID:XMOS USB Audio 2.0 ST 2023
Device #0: XMOS USB Audio 2.0 ST 2023 Manufacturer: Model UID: XMOS USB Audio 2.0 ST 2023 UID: XMOS USB Audio 2.0 ST 2023
