Failure to load after update
I tried to load, and it wanted to update. Then it said I had to install windowsdesktop runtime 8. 0.8 x64
If I do that, it then leaves me nowhere to go. Nothing happens.
It is a Microsoft .net runtime update. Audirvana asked me the same. The first .net runtime install failed. After that I clicked on the .net link in the Audirvana start screen and tried again. After that everything worked without problems.
