The Audirvana FAQ at https://audirvana.com/support/ says: “Is it possible to use an equalizer,… filters? … And you can now use the equalizers provided in macOS.”
Where are these equalizers? I only found equalizers in iTunes but those don’t seem to affect the sound of Audirvana. thx.
Hello @nobodyknows, In your audio settings of Audirvana, when you enable the Audio Unit capability and you want to choose an equalizer/filter, you will have by default this list of Apple equalizer/filter:
