I am new and have one question:
It seems I cannot find a way to change the playback point within a track, e.g. I want to play a piece from 5 minutes into the piece, or I want to listen again to a theme that I missed, a few seconds back.
There is a transport bar which I can move with the mouse or the finger on the iPad remote, but playback always continues where it was before, I can also not scrub or fast-forward to a point later in the track. In Audirvana+ I cannot move the play marker at all.
Is there a solution? I listen to classical music mainly, so pieces tend to be longer.
I’m also experiencing this issue. Has it never been solved or addressed?
Same problem here on Windows 10 laptop. No fast forward. Anyone there with an answer?
Thank you.
This functionality is taken from your DAC, if he don’t support it then you won’t be able to use it.
@Antoine: Fast-forward and rewind is working in Apple’s Music, VLC,… any other programs except in Audirvana, in combination with my Pro-Ject USB DAC and amplifier. Can you explain why this is not working on Audirvana. For me it seems this is Software related.
And if I use Audirvana in Music Integrated Mode then I can also use the functionalities like rewind,… in the Music software.
Hello @calabash,
Hi @Antoine
here is the debug info:
Registriert nach XXXXXXXX
Sync list: 0 folders
iTunes/Music library synchronization: last synchronized on Sat Oct 24 16:19:58 2020
Library database path: /Users/markus/Library/Application Support/Audirvana/AudirvanaPlusDatabaseV2.sqlite
Burr-Brown Japan PCM2702
Model UID:Burr-Brown Japan PCM2702:08BB:2702
UID:AppleUSBAudioEngine:Burr-Brown Japan:Burr-Brown Japan PCM2702:14600000:1
Hog Mode is on
ID 0x2b Burr-Brown Japan PCM2702 Manufacturer:Burr-Brown Japan
Model UID:Burr-Brown Japan PCM2702:08BB:2702 UID:AppleUSBAudioEngine:Burr-Brown Japan:Burr-Brown Japan PCM2702:14600000:1
3 available sample rates up to 48000Hz
32000
Stream ID 0x2c 2 channels starting at 1
12 virtual formats:
1 ch Mixable linear PCM Interleaved 32 little endian Signed Float 48kHz
1 ch Mixable linear PCM Interleaved 32 little endian Signed Float 44.1kHz
1 ch Mixable linear PCM Interleaved 32 little endian Signed Float 32kHz
1 ch Non-mixable linear PCM Interleaved 16 little endian Signed Integer 48kHz
1 ch Non-mixable linear PCM Interleaved 16 little endian Signed Integer 44.1kHz
1 ch Non-mixable linear PCM Interleaved 16 little endian Signed Integer 32kHz
12 physical formats
1 ch Mixable linear PCM Interleaved 16 little endian Signed Integer 48kHz
1 ch Mixable linear PCM Interleaved 16 little endian Signed Integer 44.1kHz
1 ch Mixable linear PCM Interleaved 16 little endian Signed Integer 32kHz
Local devices found : 6
Device #0: ID 0x39 DELL P3418HW Manufacturer: Apple Inc. Model UID: AppleGFXHDA:0 UID: AppleGFXHDAEngineOutputDP:30001:0:{AC10-F102-4132544C}
Device #1: ID 0x51 Ausgang (integriert) Manufacturer: Apple Inc. Model UID: AppleHDA:7 UID: AppleHDAEngineOutput:1F,3,0,1,2:0
Device #2: ID 0x4a Line-Ausgang (integriert) Manufacturer: Apple Inc. Model UID: AppleHDA:7 UID: AppleHDAEngineOutput:1F,3,0,1,3:1
Device #3: ID 0x43 Line-Ausgang (integriert) Manufacturer: Apple Inc. Model UID: AppleHDA:7 UID: AppleHDAEngineOutput:1F,3,0,1,4:2
Device #4: ID 0x2b Burr-Brown Japan PCM2702 Manufacturer: Burr-Brown Japan Model UID: Burr-Brown Japan PCM2702:08BB:2702 UID: AppleUSBAudioEngine:Burr-Brown Japan:Burr-Brown Japan PCM2702:14600000:1
Device #5: ID 0x30 AirBeamTV Audio Manufacturer: AirBeamTV B.V. Model UID: AirBeamTVDevice_ModelUID UID: tv.airbeam.audiodriver_v2_2
If you need something else let me know.
Can you try using the output of your screen DELL P3418HW? Do you experience the same behavior?
Yes it is the same behavior. And under the Point Play I only have four options: Play/Pause, next, previous, stop. But now fast-forward,…
Is it intended that Audirvana will have buttons for fast forward and rewind or that these functions will be controlled via keyboard shortcuts?
