I just tested it again. it’s weird but it works now even though i haven’t changed anything. attached anyway the debug info.
Audirvana Studio 1.8.1 (10801)
macOS 12.0 with 16GB physical RAM
Sync list: 0 folders
Library database path: /Users/thomas/Library/Application Support/Audirvana/AudirvanaDatabase.sqlite
Listening on 127.0.0.1 on port 64079
APPLE INC. HDMI
Model UID:AppleHDA:128
UID:AppleHDAEngineOutputDP:0,1,0,1,0:0:{4935-0051-01010101}
Device: 8ch Mixable linear PCM Interleaved 32bits little endian Signed Float, 32 bytes per frame 44.1kHz
Hog Mode is on
ID 0x55 HDMI
Model Name: Apple Inc. HDMI
Model UID: AppleHDA:128
UID: AppleHDAEngineOutputDP:0,1,0,1,0:0:{4935-0051-01010101}
7 available sample rates up to 192000Hz
32000
Multichannel: 8 channels
Channel 2 unused
Channel 3 unused
Channel 4 unused
Channel 5 unused
Channel 6 unused
Channel 7 unused
Number of channels: 8
Simple stereo device: No
Stream ID 0x56 8 channels starting at 1
10 virtual formats:
8 ch Mixable linear PCM Interleaved 32 little endian Signed Float 192kHz
8 ch Mixable linear PCM Interleaved 32 little endian Signed Float 176.4kHz
8 ch Mixable linear PCM Interleaved 32 little endian Signed Float 96kHz
8 ch Mixable linear PCM Interleaved 32 little endian Signed Float 88.2kHz
8 ch Mixable linear PCM Interleaved 32 little endian Signed Float 48kHz
8 ch Mixable linear PCM Interleaved 32 little endian Signed Float 44.1kHz
8 ch Mixable linear PCM Interleaved 32 little endian Signed Float 32kHz
24 physical formats
8 ch Mixable linear PCM Interleaved 24 little endian Signed Integer aligned low in 32bit 192kHz
8 ch Mixable linear PCM Interleaved 24 little endian Signed Integer aligned low in 32bit 176.4kHz
8 ch Mixable linear PCM Interleaved 24 little endian Signed Integer aligned low in 32bit 96kHz
8 ch Mixable linear PCM Interleaved 24 little endian Signed Integer aligned low in 32bit 88.2kHz
8 ch Mixable linear PCM Interleaved 24 little endian Signed Integer aligned low in 32bit 48kHz
8 ch Mixable linear PCM Interleaved 24 little endian Signed Integer aligned low in 32bit 44.1kHz
8 ch Mixable linear PCM Interleaved 24 little endian Signed Integer aligned low in 32bit 32kHz
8 ch Mixable linear PCM Interleaved 20 little endian Signed Integer aligned low in 32bit 192kHz
8 ch Mixable linear PCM Interleaved 20 little endian Signed Integer aligned low in 32bit 176.4kHz
8 ch Mixable linear PCM Interleaved 20 little endian Signed Integer aligned low in 32bit 96kHz
8 ch Mixable linear PCM Interleaved 20 little endian Signed Integer aligned low in 32bit 88.2kHz
8 ch Mixable linear PCM Interleaved 20 little endian Signed Integer aligned low in 32bit 48kHz
8 ch Mixable linear PCM Interleaved 20 little endian Signed Integer aligned low in 32bit 44.1kHz
8 ch Mixable linear PCM Interleaved 20 little endian Signed Integer aligned low in 32bit 32kHz
8 ch Mixable linear PCM Interleaved 16 little endian Signed Integer 192kHz
8 ch Mixable linear PCM Interleaved 16 little endian Signed Integer 176.4kHz
8 ch Mixable linear PCM Interleaved 16 little endian Signed Integer 96kHz
8 ch Mixable linear PCM Interleaved 16 little endian Signed Integer 88.2kHz
8 ch Mixable linear PCM Interleaved 16 little endian Signed Integer 48kHz
8 ch Mixable linear PCM Interleaved 16 little endian Signed Integer 44.1kHz
8 ch Mixable linear PCM Interleaved 16 little endian Signed Integer 32kHz
Device #0: ID 0x31 Ausgang (integriert) Manufacturer: Apple Inc. Model UID: AppleHDA:128 UID: AppleHDAEngineOutput:1B,0,1,1:0 Model Name: Apple Inc. Ausgang (integriert)
Device #1: ID 0x55 HDMI Manufacturer: Apple Inc. Model UID: AppleHDA:128 UID: AppleHDAEngineOutputDP:0,1,0,1,0:0:{4935-0051-01010101} Model Name: Apple Inc. HDMI
UPnP devices found : 6
Device #0: ID 0x0 Marantz SR7015 UID: uuid:4894c19b-1b39-1a1f-0080-000678455302 Location: http://192.168.178.39:60006/upnp/desc/aios_device/aios_device.xml
Device #1: ID 0x0 Block CR-10 0022619c31c0 UID: uuid:3DCC7100-F76C-11DD-87AF-0022619C31C0 Location: http://192.168.178.55:8080/dd.xml
Device #2: ID 0x0 Marantz SR7015 UID: uuid:9355a9e1-e8ec-17af-0080-000678455302 Location: http://192.168.178.39:60006/upnp/desc/aios_device/aios_device.xml
Device #3: ID 0x0 Marantz SR7015 UID: uuid:e0785903-2e3f-16cb-0080-000678455302 Location: http://192.168.178.39:60006/upnp/desc/aios_device/aios_device.xml
Device #4: ID 0x0 Marantz SR7015 UID: uuid:893c639d-ca3c-c739-845b-718aacc9c245 Location: http://192.168.178.39:60006/upnp/desc/aios_device/aios_device.xml
Device #5: ID 0x0 Marantz SR7015 UID: uuid:d4b7e041-1d30-ca1c-df42-37e064744eda Location: http://192.168.178.39:60006/upnp/desc/aios_device/aios_device.xml
