As a way to change audio settings for plugins via the remote app. Allow saving a plugin change on the host to a named independent slot, instead of using the last saved settings when selecting a plugin for a place in the Processing queue, pick from one of these slots to load the environment (settings) of the plugin when saved to that slot. If possible. Not sure if the plugin saves only one instance per host by it’s own design or not.
Remote could allow picking a plugin/preset combo in this way. Limited but goes beyond just having one preset per plugin to turn on remotely.
