Filters Editor problems
Hi,
I’m having problems with Filters Editors. I’m able to choose a filter, in the example below Album Artist, but when I want to choose an Album Artists, nothing happens. Sometimes it suddenly works, but when I’m then going back to change artist, I can’t, again nothing happens.
I’m running on an Intel NUC with Windows 11 Pro and the machine is only used as a music server with remote access from my laptop.
Any ideas for help?
Hi @emarkussen , do you mean when you click on “All 77 album artists”, nothing show up?
Yes, exactly…no matter where I click. On the arrow down or in the field.
Could you please send a screenshot of your entire interface when you get this issue?
Hi guys, I did a screen recording but the forum will not allow me to upload it. Basically what it showed is that after you open the filter and select an artist or artists, click outside of the list somewhere else on the screen, it you click the list, or the arrow as you mentioned, nothing will change.
Once you want to go back to your many thousands of artists click the total again, and again make sure you click outside of the list. I mainly do my on the iPad but from memory I think the Computer (albeit a MacBook Air) is the same. I assume it should be the same on a Windows Computer.
Hope that helps.
Can you send it sat [email protected] if it’s not 20MB?
It’s 25, so I will trim a little and send to you. :+1:
@Antoine Done :+1:
What you sent me is form the Remote app, The issue @emarkussen is in the Desktop app.
Exctly - and here are my new screenshot as requested :wink:
Have tested it on my MacBook Air and the filter is working correctly just by clicking the section on the drop down menu. Also correctly doing multiple selections. Again it’s not a Windows Desktop and been a long time since I used one,
Other than the old “Have you turned it off and on again” maybe try a right mouse click on the selection, rather than a left mouse click. :+1:
Hi ChiliHot, thanks for your suggestions, snd yes, I have tried restarting both Audirvana and the computer, nothing helps, neither do right clicking or anything else.
Sorry to hear that. Hopefully @Antoine can find if it is a bug or not and not just happening on your system.
Do you mind me asking what you are using the filter to find? There may be a work around we can find for you in the meantime.
Yeah, lets see what @Antoine can work out, hopefully :slight_smile:
I’m using the filter to clean up in my tracks, when I’m finished ripping all cd’s that I have with an artist. I use the “Album Artist” filter, choose Stevie Nicks (when it works) and are now only displayed tracks with Stevie Nicks. I go through the list and always delete tracks from compilation albums, that I alredy have on the original studioalbum, but of course only if it’s the exact same version.
If you click on the icon in the middle to make this window a pop-up, can you see the menu to select value?
@Antoine - that really did it for me :slight_smile: Thank you, thank yo, thank you, that must have been what I have done earlier, when t worked :slight_smile: Issue solved :blue_heart:
