First issues with my FiiO K5 PRO
Hi
Just started the trial period.
  1. The program claims my DAC hasn’t got DSD support, which it actually have.
  2. Playing some demo files I have. Some have awful clipping at some points.
    In the setup I then set the +6dB -> 0 dB, and it disappeared.
    But as +6 dB is default setting and I’m, deviating from this I assume I have an odd thing here.
    Any explanations why I can’t use default setting?
    br Lars
Hello @LarsRas,
Hi
Sure:
macOS 10.16.0 with 16384MB RAM
AUTO: /Users/lr/MusicLocal/New
Library database path: /Users/lr/Library/Application Support/Audirvana/AudirvanaPlusDatabaseV2.sqlite
FiiO K5 Pro
Model UID:FiiO K5 Pro:2972:0047
UID:AppleUSBAudioEngine:GuangZhou FiiO Electronics Co.,Ltd:FiiO K5 Pro:2200000:1
Hog Mode is on
ID 0x2d FiiO K5 Pro Manufacturer:GuangZhou FiiO Electronics Co.,Ltd
Model UID:FiiO K5 Pro:2972:0047 UID:AppleUSBAudioEngine:GuangZhou FiiO Electronics Co.,Ltd:FiiO K5 Pro:2200000:1
Stream ID 0x2e 2 channels starting at 1
30 virtual formats:
40 physical formats
2 ch Mixable linear PCM Interleaved 16 little endian Signed Integer 768kHz
Local devices found : 3
Device #0: ID 0x36 BenQ PD2700U Manufacturer: BNQ Model UID: 09D12E80-0000-0000-211E-0104B53C2278 UID: 09D12E80-0000-0000-211E-0104B53C2278
Device #1: ID 0x2d FiiO K5 Pro Manufacturer: GuangZhou FiiO Electronics Co.,Ltd Model UID: FiiO K5 Pro:2972:0047 UID: AppleUSBAudioEngine:GuangZhou FiiO Electronics Co.,Ltd:FiiO K5 Pro:2200000:1
Device #2: ID 0x30 Mac mini Speakers Manufacturer: Apple Inc. Model UID: Speaker UID: BuiltInSpeakerDevice
Can you set the native DSD read method to “DSD over PCM 1.0” in the device section of the audio settings page.
If your DAC has a volume control, you may need to ensure it is set at 100% during DSD playback to prevent its USB interface from damaging the DSD signal.
