Just downloaded Audirvana for the first time on my Mac. I followed the directions and I got this when trying to view my music in the library “Loading…” No progress bar and it has said “Loading…” for 30 minutes already. Is this normal for first time use? I do have a large library. Running 10.13.6 High Sierra
Please advise thank you
Hello @doghousestudio,
Thanks for your help. I’d really like to get this working and stop using JRiver Media Center. Here is the debug info
macOS 10.13.6 with 8192MB RAM
Sync list: 0 folders
Library database path: /Users/rodgercarter/Library/Application Support/Audirvana/AudirvanaPlusDatabaseV2.sqlite
Built-in Output
Model UID:
UID:
ID 0x34 Built-in Output Manufacturer:Apple Inc.
Model UID:AppleHDA:15 UID:AppleHDAEngineOutput:1F,3,0,1,1:0
3 available sample rates up to 96000Hz
Stream ID 0x35 2 channels starting at 1
3 virtual formats:
3 physical formats
Device #0: ID 0x34 Built-in Output Manufacturer: Apple Inc. Model UID: AppleHDA:15 UID: AppleHDAEngineOutput:1F,3,0,1,1:0
Device #1: ID 0x28 Pro Tools Aggregate I/O Manufacturer: Apple Inc. Model UID: com.Avid.ProToolsAnalogIOAggregateDevice UID: com.Avid.ProToolsAnalogIOAggregateDevice
