With an older A. Plus version 3.2.15 all AUs are selectable and work flawlessly !
I am running 3.5.15 on a MBP (macOS 10.14.6) and the audio units only work if I have "Realtime control (not for DSD playback) selected. Then the gui for Pro-Q3 opens and I can adjust settings and hear the result. Once I deselect the realtime control slider, the a.u.'s stop working, both visually and audio-ly.
Same here, A+ is fine, Audirvana 3.5.15 is a no go.
I do have the same problems. Audio Units in Audirvana 3.5.15 can not be configured, while they do work in Audirvana plus.
I don´t know if there was a silence update, from from today it works as it should. I did not change anything, Audio Units just work.
I 've just checked on my Mac mini. Still no changes.
When I opened App on my Mac mini I needed to enter License Key and configure Audirvana settings.
I also de-authorised my MacBook Pro ( where Audio Units work fine ) and checked again my Mac mini. Nothing.
Seems I’ll continue to use Audeze Reveal Plug In with Roon SW.
I checked and it’s still a “nope” for me. At this point I’d take a covert fix.
The silence on this and other issues from Audirvana support is baffling. At least an acknowledgement that these posts are being read - even if they don’t have a solution - would be a refreshing change.
I have the same issue with the license. Every few days I’ll launch 3.5.x to see if there is a software update (fix) and sometimes I have to re-enter, sometimes not. I just roll my eyes and do it.
Same problem for me on 3.5.16 which I just updated hoping it would help the problem with 3.5.15. The problem occurred the first time when I installed Reverberate Core from Liquidsonics to do convolution. Since then, no AU works. I have completely uninstalled everything, rebooted, etc… but the problem remains.
However, it works very fine on version 2.6.9 which I was using until I upgraded to 3.5 last week…
When the problem occurs a new DAC appears called CADefaultDeviceAggregate-2852-0 next to the other outputs possible, which is both strange and doesn’t help anything since you can’t do anything with it.
Hope this problem can be fixed quickly since I need convolution and UPnP, and Audirvana is useless without this working properly.
Thanks.
Philippe.
Can you first update to the latest version (3.5.16), and then send me by email or PM the crash report if you still get any crash, with details on how to reproduce?
Without such information, it is difficult to investigate…
That’s why I was asking also for logs form the Console.
@rshinze: Regarding the issue configuring the Audio Unit, do you get nothing, or a black screen? The later shows the Audio Unit is still using Open GL deprecated API that have been removed from Mojave when run on recent host applications.
What you have experienced shows the AU configuration works well with the old API (v2), but not with the one Apple is pushing for (V3).
Actually, I did update to 3.5.16. It doesn’t crash anymore. At least, I couldn’t replicate the crash, but nothing happens when I click on “configurer” in front of the AU I select, besides creating this strange new “DAC” output.
Here is the log on my computer. You can see this new “DAC” in the list as Device #1.
“Device #1: ID 0x79 CADefaultDeviceAggregate-2852-6 Manufacturer: Apple Inc. Model UID: CADefaultDeviceAggregate-2852-6 UID: CADefaultDeviceAggregate-2852-6”
Here is the full log:
Audirvana Mac Version 3.5.16 (3546)
macOS 10.13.6 with 10240MB RAM
Licence enregistrée pour xxxxxx xxxxxx (I removed my name to make this post)
AU plugin #0: Effet - LiquidSonics Reverberate Core (1.3.1)
AU plugin #1: None
AU plugin #2: None
AU plugin #3: None
AUTO: /Users/xxxxxxxxxxxx/Music/Base Musique
Library database path: /Users/xxxxxxxxxxx/Library/Application Support/Audirvana/AudirvanaPlusDatabaseV2.sqlite
Max. memory for audio buffers: 3634MB
Sortie intégrée
Model UID:AppleHDA:28
UID:AppleHDAEngineOutput:1B,0,1,1:0
Active Sample Rate: 96kHz
ID 0x2e Sortie intégrée Manufacturer:Apple Inc.
Model UID:AppleHDA:28 UID:AppleHDAEngineOutput:1B,0,1,1:0
Stream ID 0x2f 2 channels starting at 1
4 virtual formats:
12 physical formats
Device #0: ID 0x2e Sortie intégrée Manufacturer: Apple Inc. Model UID: AppleHDA:28 UID: AppleHDAEngineOutput:1B,0,1,1:0
UPnP devices found : 2
Device #0: ID 0x0 Salon (DLNA) UID: uuid:11cc5109-ca2a-7551-0000-0000349c5054 Location: http://192.168.0.33:51096/dev/11cc5109-ca2a-7551-0000-0000349c5054/desc.xml
Device #1: ID 0x0 Freebox Player UID: uuid:6af88a30-5b57-34aa-604d-33e068460cf7 Location: http://192.168.0.26:54243/device.xml
Thanks for these.
The CADefaultDeviceAggregate is an artefact of macOS when using some plugins. It has no consequences besides this unwanted audio device listed.
Can you click again on the “Configurer” button, with having launched the Console application before?
Then enter “AU editor” in the top right field of the console to show only lines from Audirvana on the AU configuration. Do you have one?
With “Realtime control (not for DSD playback)” unselected, then I hit the configure button and nothing happens. No pop up, or black window, nothing. Hope that helps.
Can you redo while the Console application is launched (instructions in my previous post)? Do you have any log entry with “AU Editor” in it?
Hi Damien,
I got the Console application finally. No entry appears for AU Editor in it even after clicking on “Configure”.
Do you need the info about Audirvana from the Console ?
In case it makes any sense for you, here it is:
erreur 17:58:37.402385 +0200 Audirvana AVAEInternal.h:70:_AVAE_Check: required condition is false: [AVAudioIONodeImpl.mm:897:SetOutputFormat: (format.sampleRate == hwFormat.sampleRate)]
erreur 17:58:37.403618 +0200 Audirvana
erreur 17:58:37.406984 +0200 Audirvana
erreur 17:58:57.665301 +0200 Audirvana Task .<21> finished with error - code: -999
par défaut 17:58:59.827297 +0200 launchservicesd CHECKIN:0x0-0x93093 5857 com.audirvana.Audirvana
erreur 17:59:00.065842 +0200 Audirvana AEGetDescData of non-desc type ‘reco’ not a good idea
par défaut 17:59:00.189730 +0200 Audirvana TIC Enabling TLS [1:0x600000162400]
par défaut 17:59:00.189781 +0200 Audirvana TIC TCP Conn Start [1:0x600000162400]
par défaut 17:59:00.190008 +0200 Audirvana Task .<1> setting up Connection 1
par défaut 17:59:00.190039 +0200 Audirvana [1 ] start
par défaut 17:59:00.377270 +0200 Audirvana TIC TLS Event [1:0x600000162400]: 1, Pending(0)
par défaut 17:59:00.503017 +0200 Audirvana TIC TLS Event [1:0x600000162400]: 2, Pending(0)
par défaut 17:59:00.519722 +0200 Audirvana UNIX error exception: 17
par défaut 17:59:00.531307 +0200 Audirvana UNIX error exception: 17
par défaut 17:59:00.537739 +0200 Audirvana UNIX error exception: 17
par défaut 17:59:00.544155 +0200 Audirvana TIC TLS Event [1:0x600000162400]: 11, Pending(0)
par défaut 17:59:00.545683 +0200 Audirvana TIC TLS Event [1:0x600000162400]: 12, Pending(0)
par défaut 17:59:00.547301 +0200 Audirvana TIC TLS Event [1:0x600000162400]: 14, Pending(0)
par défaut 17:59:00.570790 +0200 Audirvana TIC TLS Trust Result [1:0x600000162400]: 0
par défaut 17:59:00.617278 +0200 Audirvana IOHIDDeviceClass::start: elementCount=42 reportHandlerCount=1
par défaut 17:59:00.617327 +0200 Audirvana IOHIDDeviceClass::buildElements: type=0 *buffer=103957e30 *count=42 size=4032
par défaut 17:59:00.617371 +0200 Audirvana IOHIDDeviceClass::buildElements: type=1 *buffer=600000124950 *count=1 size=96
par défaut 17:59:00.698963 +0200 Audirvana TIC TLS Event [1:0x600000162400]: 20, Pending(0)
par défaut 17:59:00.699225 +0200 Audirvana TIC TCP Conn Connected [1:0x600000162400]: Err(16)
par défaut 17:59:00.699820 +0200 Audirvana TIC TCP Conn Event [1:0x600000162400]: 1
par défaut 17:59:00.700570 +0200 Audirvana TIC TCP Conn Event [1:0x600000162400]: 8
par défaut 17:59:00.700606 +0200 Audirvana TIC TLS Handshake Complete [1:0x600000162400]
par défaut 17:59:00.709131 +0200 Audirvana Task .<1> now using Connection 1
par défaut 17:59:00.709254 +0200 Audirvana Task .<1> sent request, body S
par défaut 17:59:00.980538 +0200 Audirvana Task .<1> received response, status 200 content K
par défaut 17:59:00.980770 +0200 Audirvana Task .<1> response ended
par défaut 17:59:00.982266 +0200 Audirvana TIC TCP Conn Cancel [1:0x600000162400]
par défaut 17:59:00.982873 +0200 Audirvana [1 stream, pid: 5857, url: https://api.tidalhifi.com/v1/login/username, tls] cancelled
[1.1 0DDFF2A6-64E3-4C07-A48B-3976237F9A80 .53427<->]
Connected Path: satisfied (Path is satisfied), interface: en1, ipv4, ipv6, dns
Duration: 0.792s, DNS @0.002s took 0.055s, TCP @0.062s took 0.122s, TLS took 0.323s
bytes in/out: 5756/885, packets in/out: 9/9, rtt: 0.119s, retransmitted packets: 0, out-of-order packets: 0
par défaut 17:59:00.984686 +0200 Audirvana TIC TCP Conn Destroyed [1:0x600000162400]
erreur 17:59:00.987258 +0200 Audirvana TIC Read Status [1:0x0]: 1:57
erreur 17:59:00.987308 +0200 Audirvana TIC Read Status [1:0x0]: 1:57
par défaut 17:59:00.987905 +0200 Audirvana TIC Enabling TLS [2:0x600000168dc0]
par défaut 17:59:00.987977 +0200 Audirvana TIC TCP Conn Start [2:0x600000168dc0]
par défaut 17:59:00.988280 +0200 Audirvana Task <426769EF-7CF1-40E5-B25F-76EC4852D6F5>.<1> setting up Connection 2
par défaut 17:59:00.988326 +0200 Audirvana [2 ] start
par défaut 17:59:01.115076 +0200 Audirvana TIC TLS Event [2:0x600000168dc0]: 1, Pending(0)
par défaut 17:59:01.236984 +0200 Audirvana TIC TLS Event [2:0x600000168dc0]: 2, Pending(0)
par défaut 17:59:01.259421 +0200 Audirvana TIC TLS Event [2:0x600000168dc0]: 11, Pending(0)
par défaut 17:59:01.259955 +0200 Audirvana TIC TLS Event [2:0x600000168dc0]: 12, Pending(0)
par défaut 17:59:01.260009 +0200 Audirvana TIC TLS Event [2:0x600000168dc0]: 14, Pending(0)
par défaut 17:59:01.268527 +0200 Audirvana TIC TLS Trust Result [2:0x600000168dc0]: 0
par défaut 17:59:01.388256 +0200 Audirvana TIC TLS Event [2:0x600000168dc0]: 20, Pending(0)
par défaut 17:59:01.388311 +0200 Audirvana TIC TCP Conn Connected [2:0x600000168dc0]: Err(16)
par défaut 17:59:01.388675 +0200 Audirvana TIC TCP Conn Event [2:0x600000168dc0]: 1
par défaut 17:59:01.388764 +0200 Audirvana TIC TCP Conn Event [2:0x600000168dc0]: 8
par défaut 17:59:01.388852 +0200 Audirvana TIC TLS Handshake Complete [2:0x600000168dc0]
par défaut 17:59:01.389600 +0200 Audirvana Task <426769EF-7CF1-40E5-B25F-76EC4852D6F5>.<1> now using Connection 2
par défaut 17:59:01.389732 +0200 Audirvana Task <426769EF-7CF1-40E5-B25F-76EC4852D6F5>.<1> sent request, body N
par défaut 17:59:01.529436 +0200 Audirvana Task <426769EF-7CF1-40E5-B25F-76EC4852D6F5>.<1> received response, status 200 content K
par défaut 17:59:01.529701 +0200 Audirvana Task <426769EF-7CF1-40E5-B25F-76EC4852D6F5>.<1> response ended
par défaut 17:59:01.531766 +0200 Audirvana Task .<2> now using Connection 2
par défaut 17:59:01.532194 +0200 Audirvana Task <80D55A70-6588-45C3-9981-4573A863B7F2>.<3> now using Connection 2
par défaut 17:59:01.532371 +0200 Audirvana Task .<2> sent request, body N
par défaut 17:59:01.532593 +0200 Audirvana Task <80D55A70-6588-45C3-9981-4573A863B7F2>.<3> sent request, body N
par défaut 17:59:01.670392 +0200 Audirvana Task <80D55A70-6588-45C3-9981-4573A863B7F2>.<3> received response, status 200 content K
par défaut 17:59:01.670779 +0200 Audirvana Task <80D55A70-6588-45C3-9981-4573A863B7F2>.<3> response ended
par défaut 17:59:01.672613 +0200 Audirvana Task <83256698-C67D-451C-8D25-C8D23BFCFA92>.<4> now using Connection 2
par défaut 17:59:01.672780 +0200 Audirvana Task <83256698-C67D-451C-8D25-C8D23BFCFA92>.<4> sent request, body N
par défaut 17:59:01.692618 +0200 Audirvana Task .<2> received response, status 200 content K
par défaut 17:59:01.693177 +0200 Audirvana Task .<2> response ended
par défaut 17:59:01.804785 +0200 Audirvana Task <83256698-C67D-451C-8D25-C8D23BFCFA92>.<4> received response, status 200 content K
par défaut 17:59:01.805219 +0200 Audirvana Task <83256698-C67D-451C-8D25-C8D23BFCFA92>.<4> response ended
par défaut 17:59:06.586230 +0200 Audirvana 737: component registrations changed
erreur 17:59:06.706834 +0200 Audirvana CGContextSetLineWidth: invalid line width: negative values are not allowed.
par défaut 17:59:09.874811 +0200 Audirvana LSExceptions shared instance invalidated for timeout.
erreur 17:59:10.489254 +0200 Audirvana AVAEInternal.h:70:_AVAE_Check: required condition is false: [AVAudioIONodeImpl.mm:897:SetOutputFormat: (format.sampleRate == hwFormat.sampleRate)]
erreur 17:59:10.490746 +0200 Audirvana
erreur 17:59:10.493578 +0200 Audirvana
erreur 18:00:01.923930 +0200 Audirvana TIC Read Status [2:0x600000168dc0]: 1:57
par défaut 18:00:01.924108 +0200 Audirvana TIC TCP Conn Event [2:0x600000168dc0]: 2
erreur 18:00:01.924306 +0200 Audirvana TIC Read Status [2:0x600000168dc0]: 1:57
erreur 18:00:01.924373 +0200 Audirvana TIC Read Status [2:0x600000168dc0]: 1:57
par défaut 18:00:01.924457 +0200 Audirvana TIC TCP Conn Cancel [2:0x600000168dc0]
par défaut 18:00:01.925080 +0200 Audirvana [2 stream, pid: 5857, url: https://api.tidalhifi.com/v1/users/45632853/subscription, tls] cancelled
[2.1 F2412F81-1CE9-4BB3-818B-073663964C97 .53430<->]
Duration: 60.937s, DNS @0.001s took 0.005s, TCP @0.008s took 0.118s, TLS took 0.272s
bytes in/out: 12275/1076, packets in/out: 21/11, rtt: 0.119s, retransmitted packets: 0, out-of-order packets: 0
par défaut 18:00:01.925866 +0200 Audirvana TIC TCP Conn Destroyed [2:0x600000168dc0]
Thanks for this additional logs.
I’ve been able to reproduce the issues.
- Configuration. Now fixed.
- Crash upon starting playback after configuration. I’m on this one currently.
Stay tuned…
Great ! Thank you ! Looking forward to getting the fix
Seems to be working fine. Will test further later today. Thanks for the quick update.
