I I’m trying a free license for Mac right now. The problem is that my dac only can take fixed resolution of 48 or 96 kHz. My Mac changes the resolution after Audirvana and then strange sounds come out.
Does anyone know how to solve this?
Yes USB. It’s a BSS blu USB unit going into a BSS 805 unit, in which the dacs are located. I have followed the manual for the USB unit for MAC connection.
Hello @Vonschweikert, to set the custom upsampling in Audirvana you need to go to your Audio settings
In the Upsampling section you have to activate the option and set it to “Custom” after that you can set the frequency you want to upsample to.
