Since buying the .13 ver. i have had to forced the program to quit a dozen times in 2 days. There are BIG problems.
Don’t know what’s going on. But sure would like to get to the bottom of this.
Please paste your debug information here so folks can help the best possible… It is found here: Settings → My Account → Help → Debug info
Audirvana Origin 2.5.13 (20513)
macOS 14.6.1 with 8GB physical RAM
Connected account of :
Replay Gain: by track
Sync list: 5 folders
AUTO: /Volumes/2xDSD_MUSIC/
AUTO: /Volumes/16BIT_MUSIC/
AUTO: /Volumes/24BIT_MUSIC/
AUTO: /Volumes/DSD_MUSIC/
AUTO: /Volumes/U16BIT_MUSIC/
Library database path: /Users/masonsmacmini/Library/Application Support/Audirvana/AudirvanaDatabase.sqlite
Listening on 127.0.0.1 on port 56263
Font size: regular
Language: English
My Music
Library
Startup view: Library: Albums
Use Apple Remote: yes
Number of paired remotes: 0
Screen saver disabled: no
Active method: UPnP
Preferred device: [UPnP] H390D44134 Model UID:Hegel H390 UID:uuid:1ca16aa2-1dd2-11b2-9010-4d0e2579d3da
Selected device:H390D44134
Manufacturer: Hegel
Model name: H390
Model UID: Hegel H390
UID: uuid:1ca16aa2-1dd2-11b2-9010-4d0e2579d3da
UPnP device at http://192.168.10.128:38400/description.xml
ID 0x0
Volume control: Yes
UPnP set capabilities
Maximum PCM bitdepth set: 24
Not native DSD capable
Avoid RAW PCM streams: No
http-get::audio/flac:
http-get::audio/x-flac:
http-get::audio/wav:
http-get::audio/x-wav:
http-get::application/ogg:
DLNA 1.5: Yes
Native Gapless playback: No
Missing events workaround: No
Can play native DSD: No
Volume Control: scalar
14 virtual formats:
2 ch Non-mixable linear PCM Interleaved 16 big endian Signed Integer 44.1kHz
2 ch Non-mixable linear PCM Interleaved 16 big endian Signed Integer 48kHz
0 physical formats
NrTracks: 1
MediaDuration: 0:03:36.000
CurrentURI: http://192.168.10.118:49152/audirvana/audio_f_35.wav
CurrentURIMetadata:
dc:titleShe Hates Me</dc:title>
dc:creatorPuddle Of Mudd</dc:creator>
upnp:artistPuddle Of Mudd</upnp:artist>
<upnp:author role=“Composer”>Jimmy Stewart</upnp:author>
upnp:genreRock</upnp:genre>
upnp:albumArtURIhttp://192.168.10.118:49152/audirvana/artwork_0_35.jpg</upnp:albumArtURI>
upnp:albumCome Clean</upnp:album>
upnp:originalTrackNumber6</upnp:originalTrackNumber>
nextURI:
nextURIMetadata:
PlayMedium: NETWORK
Current transport actions:
Pause,Stop,Seek,X_DLNA_SeekTime
<?xml version="1.0"?> 1 0 DMR-1.50 urn:schemas-upnp-org:device:MediaRenderer:1 H390D44134 Hegel http://www.hegel.com H390 H390 1.0 http://www.hegel.com uuid:1ca16aa2-1dd2-11b2-9010-4d0e2579d3da http://192.168.10.128 urn:schemas-upnp-org:service:RenderingControl:1 urn:upnp-org:serviceId:RenderingControl /RenderingControl.xml /RenderingControl /RenderingControl/eventSub urn:schemas-upnp-org:service:AVTransport:1 urn:upnp-org:serviceId:AVTransport /AVTransport.xml /AVTransport /AVTransport/eventSub urn:schemas-upnp-org:service:ConnectionManager:1 urn:upnp-org:serviceId:ConnectionManager /ConnectionManager.xml /ConnectionManager /ConnectionManager/eventSub http://192.168.10.128:38400Current device RootDevice description:
<?xml version="1.0"?> 1 0 DMR-1.50 urn:schemas-upnp-org:device:MediaRenderer:1 H390D44134 Hegel http://www.hegel.com H390 H390 1.0 http://www.hegel.com uuid:1ca16aa2-1dd2-11b2-9010-4d0e2579d3da http://192.168.10.128 urn:schemas-upnp-org:service:RenderingControl:1 urn:upnp-org:serviceId:RenderingControl /RenderingControl.xml /RenderingControl /RenderingControl/eventSub urn:schemas-upnp-org:service:AVTransport:1 urn:upnp-org:serviceId:AVTransport /AVTransport.xml /AVTransport /AVTransport/eventSub urn:schemas-upnp-org:service:ConnectionManager:1 urn:upnp-org:serviceId:ConnectionManager /ConnectionManager.xml /ConnectionManager /ConnectionManager/eventSub http://192.168.10.128:38400UPnP devices found : 1
Device #0: ID 0x0 : H390D44134
Manufacturer: Hegel
Model name: H390
Local Audio Engine: CoreAudio
Device #0: ID 0x32 LG FULL HD
Manufacturer: GSM
Model UID: 1E6D555B-0000-0000-011A-010380301B78
Model name: GSM LG FULL HD
Device #1: ID 0x58 Mac mini Speakers
Model UID: Speaker
UID: BuiltInSpeakerDevice
Connected account of : mason hargreaves
Font size: regular
Language: English
My Music
Library
Active method: UPnP
Manufacturer: Hegel
Model name: H390
ID 0x0
Volume control: Yes
DLNA 1.5: Yes
14 virtual formats:
0 physical formats
NrTracks: 1
CurrentURIMetadata:
nextURI:
nextURIMetadata:
PlayMedium: NETWORK
Manufacturer: Hegel
Model name: H390
Manufacturer: GSM
Model UID: Speaker
I am reposting cause I am having a issues with tracks not playing along with maintenance functions in the software. 4 forced quits in a hour.
I have had a couple of albums (hi-res) that don’t play a track or two. Usually in the number 2-3 track. The rest play fine. (error starting device playback)
I had tried to re-sync the DB (s) on the NAS and the program locks up and requires a forced quit.
I tried to run a defrag with the same results.
I rebooted the Hegel to insure that end of the equation was okay.
I am wondering if loading the updated program over the trial ver. is creating problems. ?
Couple of things going on, Might be related, might not.
Debug info right after the error message (error starting device playback)
Max allowed volume: 5.03472
Listening on 127.0.0.1 on port 58384
Font size: regular
Language: English
My Music
Library
Active method: UPnP
Manufacturer: Hegel
Model name: H390
ID 0x0
Volume control: Yes
Max volume alert: Disabled
DLNA 1.5: Yes
Native Gapless playback: Yes
14 virtual formats:
0 physical formats
NrTracks: 1
MediaDuration: 0:02:59.000
CurrentURI: http://192.168.10.118:49152/audirvana/audioTest.pcm
CurrentURIMetadata:
dc:titletestTitle</dc:title>
nextURI:
nextURIMetadata:
PlayMedium: NONE
Play
Manufacturer: Hegel
Model name: H390
Max. memory for audio buffers: 2018MB
Manufacturer: GSM
Model UID: Speaker
Are you running a Mac Mini headless? Has Audirvana synchronized with all of your library files?
- Why would you allow gain beyond 0dB? You may be overloading your DAC…
Things to examine…
If making changes does not solve the issue… You may want to contact Hegel regarding this behavior…
The playback issues are definitely an Audirvana software issue. I Can play same album on brand X without any problems.
I suspect the rest of the database maintenance software issues I have tried to preform are related in some fashion.
I guess you have to ask yourself why a large number of other macOS platform/Audirvana users are not experiencing this behavior under similar conditions.
Don’t know and I don’t concern myself what others may or may not be experiencing.
I do read the posts in order to gain knowledge if appropriate.
What I do know is the program is not working correctly.
e.g. Won’t re-sync DB’s. Won’t delete DB’s. Won’t defrag DB’s. Won’t play certain tracks and/or albums. It locks up and the spinning wheel of death appears. Force quit required.
These other settings you suggested I review I need reference material.
Start again…
Go in Audirvana preferences panel and remove your music folder(s) there
(all the folder(s) of music you have there) delete them with minus sign.
Close Audirvana.
Go to User… Home Folder… Library… Applications Support… Audirvana Folder… Trash All the files in that folder (that is your database of music, back it up! or not) AudirvanaDatabase.sqlite is for Studio, but remove others if you have old version of .sqlite… for Studio not Starting to convert them at first launch.
trash com.audirvana.Audirvana-Studio.plist in that folder
(those are Audirvana Studio software preferences, back them up or not).
Restart Mac.
Re add your music folders (maybe one by one… like that you can see if it bugs somewhere before testing all your music at once).
Edited… if it doesn’t bug on first folder add, then close Audirvana and copy the database somewhere as a good 1 folder backup and repeat often…
I never had issues like this before upgrading.
I would like for Support to step in and provide specific detailed steps to do a complete uninstall, all files and then I will do a clean install.
hi @moneypit,
This is a good step-by-step tutorial to start from scratch Audirvāna:
Home folder is a windows term and doesn’t correlate with a Mac M1 (Arm) platform. CMD J is windows syntex.
In a Mac system the root directory would fall under Macintosh HD. In order to see or remove hidden files of an application I first would need to reference a MAC OS.
Thanks.
The steps given to you are specifically for the Mac.
@RunHomeSlow is talking about a Mac here and it does correlate with MacOS. Home folder is not a specific Windows term. In fact in Windows the term ‘Home folder’ is not common. In Windows there is a ‘User folder’ but there is no ‘Home folder’ in the user folder.
No, CMD-J is Mac syntax. Windows PCs do not have a CMD key. In Windows the CTRL key is used for keyboard shortcuts.
Just follow the steps @RunHomeSlow (and @Antoine from support confirmed) gave you for your Mac. These same steps have helped a lot of other Mac users before on this forum.
Patience please. Little bit of a learning curve here. What I have discovered is…
There is not a Home folder to speak of. (start of my confusion)
It directs you to the name of the users only, at least on this OS. 14.6.1.
Finder-Go-Home-User Log-in name-CMD J. Or Macintoch-Users-User log-in name-CMD J.
That’s clear up.
Thank you all for you help.
Sorry if I sounded impatient, but I saw some wrong assumptions in your post and I wanted to take them away
No hurries. Good luck in your efforts to solve this
It’s all good. Typed or texted words can loose continuity at times.
I can be a bit thick headed.
Not the worst or near the best of using unfamiliar software.
WIP.
Thanks Agoldnear. I think I got it…
I have tried to deleted the files in the program (app) and it doesn’t seem to be working.
The 16 bit file has been in the delete cue for over 40 minutes.
Adding any additionally tasks to the program locks it up and a forced quit is required.
Ok then, try in reverse,
close Audirvāna
and go first and delete the database .sqlite file,
After, restart Mac,
restart Audirvāna,
it should try to reload all your folders by default, let it go and wait, then see
