Sorry bitracer, I misunderstood your remark : I did that already, I tried the same FLAC as with Music and it does not work.
Have you granted audirvana to access some folders at the beginning, catalina ask for that
[sorry for the delay I was blocked : too many messages…]
thx for the hardcopies RHS.
no, Audirvana did not ask for any access to the directories where the FLACs are.
But it is recorded for the keys in accessibility.
I tried with a micromega myDAC, it worked, and then plugged again the Foster…
… and it works
Don’t understand why. I assume it reset a driver somewhere. Nice but how do I solve it again ?..
Anyway, thx RHS and bitracer for your answers. May the good music be with you in 2020 :-), and later !
Hello again,
here are a few hints in case I happen to interest Audirvana folks [ ]
The problem seems to be linked to the resolution and the buffer management by Audirvana : in fact my successful test has been done with a HR (24 bits) album in Qobuz. And when I opened a 16 album file : here it comes again.
Few tries later : 24 bits OK, 16 bits KO
When you open a 16 bits song you hear a bit of the previous song then jump to the present one, and again. That’s why I write about memory buffer management problem.
I don’t know how to raise this situation to Audirvana support if someone can direct me to them ? I am in evaluation period so maybe I don’t have the possibility to get help ?
Sincerely,
lpg
Hello @lpg, Can you send me a copy of the “Debug Info”? You can get it in Audirvana Settings>General>Debug Info
Hello @Antoine ! Thx for your concern.
Here is the dump :
Audirvana Mac Version 3.5.29 (3559)
macOS 10.15.2 with 16384MB RAMVersion d’essai utilisant une licence de démo
Effects plugins NOT ACTIVEUPSAMPLING:
Phase = 66AUDIO VOLUME:
SW volume control: OFFLIBRARY SETTINGS:
AUTO: /Users/dark/Music/Sans perte (FLAC, ALAC)
Library database path: /Users/dark/Library/Application Support/Audirvana/AudirvanaPlusDatabaseV2.sqliteACTIVE STREAMING SERVICES
Qobuz: Connected as Qobuz Studio=================== AUDIO DEVICE ========================
Max. memory for audio buffers: 12810MB
Integer mode: EnabledPreferred device:
FOSTEX USB AUDIO HP-A4
Model UID:FOSTEX USB AUDIO HP-A4:1019:0011
UID:AppleUSBAudioEngine:FOSTEX:FOSTEX USB AUDIO HP-A4:00001:1Currently playing in Integer Mode:
Device: 2ch Non-mixable linear PCM Interleaved 16bits little endian Signed Integer, 8 bytes per frame 44.1kHzActive Sample Rate: 44.1kHz
Hog Mode is onBridge settings:
Mute during sample rate change: OFFSelected device:
ID 0x2b FOSTEX USB AUDIO HP-A4 Manufacturer:FOSTEX
Model UID:FOSTEX USB AUDIO HP-A4:1019:0011 UID:AppleUSBAudioEngine:FOSTEX:FOSTEX USB AUDIO HP-A4:00001:17 available sample rates up to 352800Hz
Channel 1 mapped to 1Audio channels in use
Simple stereo device: Yes1 output streams:
Channel #1 :Stream 0 channel 1Stream ID 0x2c 2 channels starting at 1
28 virtual formats:
2 ch Non-mixable linear PCM Interleaved 16 little endian Signed Integer aligned low in 32bit 352.8kHz
2 ch Non-mixable linear PCM Interleaved 16 little endian Signed Integer aligned low in 32bit 192kHz
2 ch Non-mixable linear PCM Interleaved 16 little endian Signed Integer aligned low in 32bit 176.4kHz
2 ch Non-mixable linear PCM Interleaved 16 little endian Signed Integer aligned low in 32bit 96kHz
2 ch Non-mixable linear PCM Interleaved 16 little endian Signed Integer aligned low in 32bit 88.2kHz
2 ch Non-mixable linear PCM Interleaved 16 little endian Signed Integer aligned low in 32bit 48kHz
2 ch Non-mixable linear PCM Interleaved 16 little endian Signed Integer aligned low in 32bit 44.1kHz42 physical formats
2 ch Mixable linear PCM Interleaved 16 little endian Signed Integer aligned low in 32bit 352.8kHz
2 ch Mixable linear PCM Interleaved 16 little endian Signed Integer aligned low in 32bit 192kHz
2 ch Mixable linear PCM Interleaved 16 little endian Signed Integer aligned low in 32bit 176.4kHz
2 ch Mixable linear PCM Interleaved 16 little endian Signed Integer aligned low in 32bit 96kHz
2 ch Mixable linear PCM Interleaved 16 little endian Signed Integer aligned low in 32bit 88.2kHz
2 ch Mixable linear PCM Interleaved 16 little endian Signed Integer aligned low in 32bit 48kHz
2 ch Mixable linear PCM Interleaved 16 little endian Signed Integer aligned low in 32bit 44.1kHz
2 ch Non-mixable linear PCM Interleaved 16 little endian Signed Integer aligned low in 32bit 44.1kHzLocal devices found : 2
Device #0: ID 0x2b FOSTEX USB AUDIO HP-A4 Manufacturer: FOSTEX Model UID: FOSTEX USB AUDIO HP-A4:1019:0011 UID: AppleUSBAudioEngine:FOSTEX:FOSTEX USB AUDIO HP-A4:00001:1
Device #1: ID 0x4d Haut-parleurs MacBook Pro Manufacturer: Apple Inc. Model UID: Speaker UID: BuiltInSpeakerDeviceUPnP devices found : 0
Hope it helps to solve the issue,
Bien cordialement
I would like to reproduce your issue, with which album of Qobuz did you made your test?
For example start with Bénabar ‘le début de la suite’, which is available in HR, then switch to Bénabar ‘Reprise des négociations’ which is not, and you experience the problem.
I couldn’t reproduce your issue, have you checked if you have a firmware update of your Fostex available?
I will check, but Colibri plays the album flawlessly whereas Audirvana does not.
If I open the album from local disk in 16/44 with the Fostex : OK with Colibri KO with Audirvana.
Same thing if I open a 16/44 album with Qobuz app : OK, same album with Qobuz through Audirvana.
Did you try with a MBP 16" ?
DAC is already at latest firmware version : v1.10
sorry I mistyped : other example if I open a 16/44 album with Qobuz app : OK, same album with Qobuz through Audirvana : KO. With the Fostex DAC. Everything is ok with internal speakers.
Have you tried enabling upsampling? You can do it by going in the audio device settings in Audirvana in the upsampling section.
Hello, it works with “x2”, I don’t really understand the different options but indeed it works.
I assume the introduction of “optimizer” does the trick. Thx.
lpg
