Gapless audio not gapless
Using the trial for now. I’m trying to migrate from using iTunes to play music on my HTPC, and right now Audirvana seems to work well, except for one issue: There is a slight hiccup with gapless play. It is not seamless transition between tracks, which is odd since I’ve never had this issue with any of the other audio programs I’ve used before.
I’ve tried playing with the amount of buffer memory, and this seems to have helped a bit, but the interruption is still there, most noticeable on Pink Floyd albums.
If I can find a solution to this issue, then I think this will be my go-to software for audio. Everything else seems to work fine.
Welcome…
Please paste your Debug info here so folks can help the best possible… It is found here: Settings–> My Account–> Help–> Debug info
Audirvana Origin 2.5.13 (20513)
Windows 11 (22631) with 16GB physical RAM
Connected account of : Charles Lee
Available network interfaces:
Ethernet ({998a9fc2-d39c-4e2a-8ace-08f28d36e221}) is private
Windows Defender Firewall status for this instance of Audirvana Origin
Active profile types: all
Private profile:
Firewall: enabled
Inbound: allowed
Outbound: allowed
Notifications: enabled
Public profile:
Firewall: enabled
Inbound: blocked
Outbound: allowed
AUTO: \Diskstation\Main_Music
Library database path: C:\Users\Charles Lee\AppData\Local\Packages\Audirvana.Audirvana-d488-4ebf-b1c4-596e08349a6a_q3nymrkmej12j\LocalCache\Local\Audirvana\Audirvana\AudirvanaDatabase.sqlite
Listening on 192.168.1.100 on port 52103
Font size: regular
My Music
Library
Number of paired remotes: 0
Screen saver disabled: yes
Max. memory for audio buffers: 256MB
Local Audio Engine: WASAPI
Speakers (SMSL USB DAC)
Model UID:TUSBAUDIO_ENUM\VID_152A&PID_85DD&REV_0353&KS
UID:\?\SWD#MMDEVAPI#{0.0.0.00000000}.{c31cea0f-f5d0-4838-a915-5952f2ebf1c8}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
Active Sample Rate: 48kHz
Selected device:Speakers (SMSL USB DAC)
Manufacturer: XMOS
Model name: SMSL USB AUDIO
Model UID: TUSBAUDIO_ENUM\VID_152A&PID_85DD&REV_0353&KS
UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{c31cea0f-f5d0-4838-a915-5952f2ebf1c8}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
USB Vendor ID: 0x152a
USB Product ID: 0x85dd
MQA Decoder device
DSD via PCM 1.1
Simple stereo device: No
Device #0: AV Receiver (HD Audio Driver for Display Audio)
Manufacturer: Intel Corporation
Model UID: HDAUDIO\SUBFUNC_01&VEN_8086&DEV_2815&NID_0001&SUBSYS_00000000&REV_1000
UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{4451d635-94a4-4d75-a5c9-7d125f87f007}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
Model name: HDAUDIO\SUBFUNC_01&VEN_8086&DEV_2815&NID_0001&SUBSYS_00000000&REV_1000
Device #1: Speakers (SMSL USB DAC)
Manufacturer: XMOS
UPnP devices found : 1
Device #0: [LG] webOS TV OLED83C2PUA
UID: uuid:702693d2-8c14-765a-898c-0d3f9265407c
Manufacturer: LG Electronics.
Model name: LG TV
Chromecast devices found : 1
Device #0: Onkyo TX-NR656 E7DCAB
Model name: Onkyo TX-NR656
Alright, I’ve been battling with this for over a week, trying to figure it out. It doesn’t matter if I use WASAPI, ASIO, or KS (KS makes it worse, as it adds a noise when switching tracks). I don’t understand this. Itunes works perfectly, JRMC works perfectly, WMP works perfectly. How is this possible?
I’ve uploaded short video of the issue. It’s recorded from my iphone so audio is bad, but it illustrates the situation.
https://drive.google.com/file/d/1y1i8bmEn-eN_DYZYfirr1RZSJ50Ww_hT/view?usp=sharing
JRMC for comparison:
Another example. How it should sound:
https://drive.google.com/file/d/1XQafsV3J-7D9dvvFp3lp-7Zp5Cdvpa_i/view?usp=sharing
Audirvana:
https://drive.google.com/file/d/1ovRbK2pr-qzs1jtqT-PrLha6TmWTvIqS/view?usp=sharing
