Yeah! Absolutely. Many thanks for your interest Giovanni.
Interestingly I have a similar, but not identical, issue with Audirvana and my Rose streamer where the first few seconds of a track are repeated in"normal" mode but not if Universal Gapless mode is used.
Again, other DLNA players work fine with the Rose, and other renderers work fine with Audirvana.
I can only surmise that Audirvana has some “optimisations” in the DLNA protocol stream that most renderers handle but a small number (including yours and mine) don’t. I’m not suggesting either side is at fault - it may be an ambiguity in the protocol specification - but it’s very frustrating.
Yes, it is
UPnP is a poorly defined standard unfortunately, so the various implementations tend to have their own ‘peculiarities’.
@Steve you might perform a test by installing MinimServer on your macbook and trying to control playback to your Atoll device using mConnect Lite on your iPhone (I am assuming you have an iPhone considering you told me you don’t have any Android device)
Interesting. Thanks!
Of course MinimServer is just a media server, it does not offer any dsp features. But it can be interesting to see if your streamer works in this scenario. MinimServer is well-known so I guess it should work without issues.
I’ll try it when back home in two weeks time. Many thanks again.
Hello @Steve, just curious, have you solved the issue?
Hi GioF71. Sorry for the delay in responding to your latest message, I was away.
No, not yet. Atoll’s people are working on it. I’ll be prompt to inform you should good news emerge.
In the meantime I am using Audirvana 3.5 which works perfectly.
Ciao!
Stefano
Ok thank you! I hope this can be solved.
The nice Atoll guy, who is taking care of “my” case, tried to playback the files I sent him and everything went well. The files played until the end without any skipping. The mystery, therefore, is still there. What strikes me is that this happens with Audirvana Origin (even with the latest release) and NOT with Audirvana 3.5 and with Roon. Waiting any suggestion from the Audirvana people who, it seems, have disappeared from this thread.
Hi @Steve,
Audirvana Origin 2.5.18.1 (20519)
macOS 15.1.1 ARM64 with 16GB physical RAM
Connected account of : XXXXXXX
Local network access: allowed
Replay Gain: by album
AUTO: /Volumes/Musica/Musica/Music
Library database path: /Users/XXXXXXXX/Library/Application Support/Audirvana/AudirvanaDatabase.sqlite
Listening on on port 58020
Font size: large
My Music
Library
Use Apple Remote: yes
Number of paired remotes: 4
Screen saver disabled: yes
Active method: UPnP
Preferred device: [UPnP] ST300 Model UID:ATOLL Electronique ST300 UID:uuid:42869892-a9a5-4bde-9a15-30f687539b15
Selected device:ST300
Manufacturer: ATOLL Electronique
Model name: ST300
Model UID: ATOLL Electronique ST300
UID: uuid:42869892-a9a5-4bde-9a15-30f687539b15
UPnP device at http://192.168.1.50:16500/42869892-a9a5-4bde-9a15-30f687539b15.xml
ID 0x0
Volume control: Yes
Not automatically detected, user set to MQA Decoder
Raw DSD (msb)
UPnP set capabilities
Maximum PCM frequency set: 96000Hz
Maximum PCM bitdepth set: 24
Maximum DSD rate set: Disabled
Avoid RAW PCM streams: No
http-get::audio/x-aiff:
http-get::audio/flac:
http-get::application/ogg:
http-get::audio/x-flac:
http-get::audio/x-wav:
http-get::audio/x-m4a:
http-get::audio/ogg:
http-get::audio/mpeg:
http-get::text/xml:
http-get::audio/x-dsf:
http-get::audio/aiff:
http-get::audio/wav:
http-get::audio/m4a:
http-get::audio/x-dff:
http-get::audio/wave:
http-get::audio/aac:
http-get::audio/vorbis:
http-get::audio/mpegurl:
http-get::audio/x-mpegurl:
http-get::video/mpegurl:
http-get::video/x-mpegurl:
rtsp-rtp-udp::audio/x-aiff:
rtsp-rtp-udp::audio/flac:
rtsp-rtp-udp::audio/x-flac:
rtsp-rtp-udp::audio/x-wav:
rtsp-rtp-udp::audio/x-m4a:
rtsp-rtp-udp::audio/ogg:
rtsp-rtp-udp::audio/x-dsf:
rtsp-rtp-udp::audio/aiff:
rtsp-rtp-udp::audio/wav:
rtsp-rtp-udp::audio/m4a:
rtsp-rtp-udp::audio/x-dff:
rtsp-rtp-udp::audio/wave:
rtsp-rtp-udp::audio/aac:
rtsp-rtp-udp::audio/vorbis:
rtsp-rtp-udp::audio/mpegurl:
rtsp-rtp-udp::audio/x-mpegurl:
rtsp-rtp-udp::video/mpegurl:
rtsp-rtp-udp::video/x-mpegurl:
DLNA 1.5: Yes
Native Gapless playback: Yes
Missing events workaround: No
Can play native DSD: Yes
Volume Control: scalar
8 virtual formats:
0 physical formats
NrTracks: 1
MediaDuration: 0:03:17
CurrentURI: http://192.168.1.52:49153/audirvana/audio_f_0.wav
CurrentURIMetadata:
dc:titleII. Menuet (1726)</dc:title>
dc:creatorAkademie für Alte Musik Berlin</dc:creator>
upnp:artistAkademie für Alte Musik Berlin</upnp:artist>
<upnp:author role=“Composer”>Georg Caspar Schürmann</upnp:author>
upnp:genreClassical</upnp:genre>
upnp:albumArtURIhttp://192.168.1.52:49153/audirvana/artwork_0_0.jpg</upnp:albumArtURI>
upnp:albumOuvertüren: Music for the Hamburg Opera</upnp:album>
nextURI: http://192.168.1.52:49153/audirvana/audio_f_1.wav
III. Ballet - Entre (1726)
Classical
http://192.168.1.52:49153/audirvana/artwork_1_1.jpg
3
object.item.audioItem.musicTrack
PlayMedium: NETWORK
Current transport actions:
Pause,Stop,Next,Seek
<?xml version="1.0"?> 1 0 QPlay:2.1 urn:schemas-upnp-org:device:MediaRenderer:1 ST300 ATOLL Electronique https://www.atoll-electronique.com/ ST300 http://www.atoll-electronique.com/ 2301005637 uuid:42869892-a9a5-4bde-9a15-30f687539b15 image/png 120 120 24 /LibRygelRenderer-120x120x24.png image/png 48 48 24 /LibRygelRenderer-48x48x24.png image/jpeg 120 120 24 /LibRygelRenderer-120x120x24.jpg image/jpeg 48 48 24 /LibRygelRenderer-48x48x24.jpg urn:schemas-upnp-org:service:ConnectionManager:1 urn:upnp-org:serviceId:ConnectionManager /xml/ConnectionManager.xml /Control/LibRygelRenderer/RygelSinkConnectionManager /Event/LibRygelRenderer/RygelSinkConnectionManager urn:schemas-upnp-org:service:AVTransport:1 urn:upnp-org:serviceId:AVTransport /xml/AVTransport2.xml /Control/LibRygelRenderer/RygelAVTransport /Event/LibRygelRenderer/RygelAVTransport urn:schemas-upnp-org:service:RenderingControl:1 urn:upnp-org:serviceId:RenderingControl /xml/RenderingControl2.xml /Control/LibRygelRenderer/RygelRenderingControl /Event/LibRygelRenderer/RygelRenderingControl urn:schemas-tencent-com:service:QPlay:1 urn:tencent-com:serviceId:QPlay /xml/QPlayDescription.xml /Control/LibRygelRenderer/QPlay /Event/LibRygelRenderer/QPlay http://192.168.1.50:80/ DMR-1.51Current device RootDevice description:
<?xml version="1.0"?> 1 0 QPlay:2.1 urn:schemas-upnp-org:device:MediaRenderer:1 ST300 ATOLL Electronique https://www.atoll-electronique.com/ ST300 http://www.atoll-electronique.com/ 2301005637 uuid:42869892-a9a5-4bde-9a15-30f687539b15 image/png 120 120 24 /LibRygelRenderer-120x120x24.png image/png 48 48 24 /LibRygelRenderer-48x48x24.png image/jpeg 120 120 24 /LibRygelRenderer-120x120x24.jpg image/jpeg 48 48 24 /LibRygelRenderer-48x48x24.jpg urn:schemas-upnp-org:service:ConnectionManager:1 urn:upnp-org:serviceId:ConnectionManager /xml/ConnectionManager.xml /Control/LibRygelRenderer/RygelSinkConnectionManager /Event/LibRygelRenderer/RygelSinkConnectionManager urn:schemas-upnp-org:service:AVTransport:1 urn:upnp-org:serviceId:AVTransport /xml/AVTransport2.xml /Control/LibRygelRenderer/RygelAVTransport /Event/LibRygelRenderer/RygelAVTransport urn:schemas-upnp-org:service:RenderingControl:1 urn:upnp-org:serviceId:RenderingControl /xml/RenderingControl2.xml /Control/LibRygelRenderer/RygelRenderingControl /Event/LibRygelRenderer/RygelRenderingControl urn:schemas-tencent-com:service:QPlay:1 urn:tencent-com:serviceId:QPlay /xml/QPlayDescription.xml /Control/LibRygelRenderer/QPlay /Event/LibRygelRenderer/QPlay http://192.168.1.50:80/ DMR-1.51UPnP devices found : 1
Device #0: ID 0x0 : ST300
Location: http://192.168.1.50:16500/42869892-a9a5-4bde-9a15-30f687539b15.xml
Model name: ST300
Max. memory for audio buffers: 12724MB
Local Audio Engine: CoreAudio
Local devices found : 4
Device #0: ID 0x75 Studio Display Speakers
Model UID: Studio Display Audio Control:05AC:1114
UID: AppleUSBAudioEngine:Apple Inc.:Studio Display:00008030-001069920AD0802E:8,9
USB Vendor ID: 0x05ac
USB Product ID: 0x1114
Model name: Apple Inc. Studio Display Speakers
Device #1: ID 0x5d Altoparlanti MacBook Air
Model UID: Speaker
UID: BuiltInSpeakerDevice
Model name: Apple Inc. Altoparlanti MacBook Air
Device #2: ID 0x36 BoomAudio
Manufacturer: Global Delight Technologies Pvt. Ltd.
Model UID: GDAudioDevice_ModelUID
UID: GDAudioDevice_UID
Model name: Global Delight Technologies Pvt. Ltd. BoomAudio
Device #3: ID 0x51 Screenflick Loopback
Manufacturer: Araelium Group
Model UID: com.araeliumgroup.screenflick.loopback
Model name: Araelium Group Screenflick Loopback
DEBUG INFO UPDATED during continously skipping playing.
Hi @Steve,
I tried an album called Life Live by Thin Lizzy and got the issue. I will investigate about it next week
At last someone got it! Many thanks Antoine!
