Garbled/distorted sound after 20+ minutes
After 20+ minutes of continuous listening to playlists, tracks suddenly become barely decipherable - glitchy, like digital distortion.
Log pasted below.
Thank you so much in advance for any thoughts.
CHAIN: Tidal, Audirvana, iMac, USB out to Rotel A12 MKII w/ onboard DAC.
LOG:
Audirvana Studio 2.9.6.1 (20908)
macOS 15.3.1 x86_64 with 16GB physical RAM
Connected account of : Dave Reilly
Local network access: allowed
	AU plugin #1: None
	AU plugin #2: None
	AU plugin #3: None
AUTO: /Users/davereilly/Music/iTunes
iTunes/Music library synchronization: last synchronized on Sun Dec 3 10:54:21 2023
Sort and display order: en_US
Library database path: /Users/davereilly/Library/Application Support/Audirvana/AudirvanaDatabase.sqlite
Tracks with no MBID: 4274
Listening on on port 61568
TIDAL: Connected as PREMIUM
Font size: large
My Music
Radios
Podcasts
Streaming
Use media keys: no
Use Apple Remote: yes
Number of paired remotes: 2
Screen saver disabled: no
Local Audio Engine: CoreAudio
Exclusive access: ON
Integer mode: ON
Use max I/O buffer size: OFF
ROTEL ROTEL USB Audio 2.0
Model UID:ROTEL USB Audio 2.0:278B:5100
UID:AppleUSBAudioEngine:ROTEL:ROTEL USB Audio 2.0:14400000:1
Active Sample Rate: 88.2kHz
Selected device:ROTEL USB Audio 2.0
Manufacturer: ROTEL
Model name: ROTEL USB Audio 2.0
Model UID: ROTEL USB Audio 2.0:278B:5100
UID: AppleUSBAudioEngine:ROTEL:ROTEL USB Audio 2.0:14400000:1
USB Vendor ID: 0x278b
USB Product ID: 0x5100
ID 0x63
Audio buffer frame size : 27 to 4096 frames
Max volume alert: Disabled
Stream ID 0x64 2 channels starting at 1
32 virtual formats:
2 ch Non-mixable linear PCM Interleaved 24 little endian Signed Integer aligned high in 32bit 384kHz
2 ch Non-mixable linear PCM Interleaved 24 little endian Signed Integer aligned high in 32bit 352.8kHz
48 physical formats
2 ch Mixable linear PCM Interleaved 24 little endian Signed Integer aligned high in 32bit 384kHz
2 ch Mixable linear PCM Interleaved 24 little endian Signed Integer aligned high in 32bit 352.8kHz
Local devices found : 3
Device #0: ID 0x57 Built-in Output
Model UID: AppleHDA:16
UID: AppleHDAEngineOutput:1F,3,0,1,1:0
Device #1: ID 0x63 ROTEL USB Audio 2.0
Manufacturer: ROTEL
Device #2: ID 0x47 eqMac
Manufacturer: Bitgapp Ltd
Model UID: EQMDeviceModelUID
UID: EQMDevice
Model name: Bitgapp Ltd eqMac
Wi-Fi
You are using more than 75% of your 16GB of System RAM for playback pre-load memory (13.3GB)… lower this to 4GB…
Also remove the stand-alone Bitgapp Ltd ‘eqMac’ application as it is competing with Audrivāna for Core Audio API’s… It is best to utilize the Audio Units plug-in architecture of Audirvāna for this DSP.
Also, it is not the best practice to store your music library on the System Drive…
If you are streaming music when this happens, this maybe related to bandwidth throttling by your ISP or LAN issues…
Thanks very much for this!
Unfortunately, the suggested changes did not resolve the issue.
I am indeed strictly streaming (not using library). I just tested my download speed, which is 249 Mbps.
In this case, it is safe to assume that this is not related to Audirvāna, as it appears playback is as expected until this behavior appears… Get a reading of your internet download throughput at the time this behavior happens.
Note:
Downloads slow over time : r/TIdaL - Reddit :
https://www.reddit.com/r/TIdaL/comments/se6xw6/downloads_slow_over_time/
Thank you.
I just tried that, and still got a high reading:
After 6 tracks or so into a playlist, the garbled sound started. While letting it continue to play, I ran a google speed test at 274 Mbps down.
If it’s helpful to know, this immediately resolves the issue:
I pause playback, click the lock button to “release audio output”, then relock it, and then resume playing.
I just noticed this… set this to ON
Thank you. I see that setting listed in the log I pasted, but I am not finding where to change it in Audirvana Studio. The only setting with the word buffer in it is an on/off toggle for Large Core I/O Buffer, under Low Level Playback Options for the DAC. Is that it? Web searches are no help.
Yes…
You will find the online ‘Help’ manual very valuable in understanding the configuration settings… It is found in the top-right of the settings pop-up window the (i) icon.
Also, make sure you have the latest firmware update in your Rotel box… USB audio-signals are delivered to the DAC receiver, asynchronously, where the digital-audio signal and metadata about sample-rate is then managed by the DAC signal clocking topologies… if the signal flow is interrupted or delayed long enough the receiver buffer will run low (under-runs) and be unable to deliver data to the DAC system clocking topology, which will precipitate garbling and drop-outs in the playback.
This latency/interruption in the LAN or WAN signal connection will play into this… It is the data throughput from the Streaming provider’s server that is the key… the ISP throughput you are measuring is a ping to-and-from a localized network server… However on your LAN a variety of influences can randomly influence the data flow to the computer.
Many thanks for this. Greatly appreciated.
Has anyone tried using Resplendence Software - LatencyMon: suitability checker for real-time audio and other tasks to see if there are any latency issues?
Oops, my bad… Wrong OS…
