You can use Grouping tag available in the metadata editor.
Once you have done you’ll find them grouped by the name of the composition inside the album and can play a single group
Thanks @stefano_mbp: I can see it’s possible. But, as I say, I am new to Audirvana. Is there a doc, or page somewhere that explains the exact procedure/steps, please?
I retrieved the screenshots from Audirvana site, just google for “Audirvana metadata”, afaik there is no other documentation.
You have to group tracks.
Open an album, select the tracks belonging to the same composition, then write in “Grouping” tag the composition name and save, that’s it.
Thanks again, @stefano_mbp, for your help with Yate meta tagging! I understand the model now and am making real progress .
But I can’t get Grouping to work - as in the second screenshot here, where the actual movements - two groups of four individual piano pieces - are (or appear to be) indented to the right of the actual work name (Impromptus… and Piano Sonata…) just as I want them to be.
Audirvana 3.5.41 on macOS 10.14.6.
Is it perhaps a View or display setting which I’ve missed?
the only idea that comes to me if you can’t get the screenshot result is this: grouping works if the tracks are in sequence, if they are not in sequence grouping will not group them
