Hi!
I tried Audirvana Origin and the behaviour is the same as A3.5
I’m in imac macos monterey, connected to Gustard R26 DAC via ethernet cable.
A3.5 + origin can detect the “gustarender” and play music to it, however, Audirvana intermittently freezes, or stays stuck on LOADING FIRST TRACK, and cannot play any music. Even if I close audirvana and reopen its stuck. If I shut off and restart the R26 dac, it will work again. Other times, even when its working, Audirvana doesn’t display the current song or progress, just showing the first song it played.
I’m wondering if USB connection would be more stable. I was contemplating getting the Gustard U18 DDC to connect to the R26.
Any thoughts what might be happening via LAN , or whether its better to use USB?
Thank you
