No plugin active
Replay Gain: by album
Manual: (OFFLINE) /Volumes/music/
Library database path: /Users/administrator/Library/Application Support/Audirvana/AudirvanaDatabase.sqlite
Listening on 127.0.0.1 on port 52117
Max. memory for audio buffers: 15360MB
M2TECH HIFACETWO UAC2 OUTPUT
Model UID:hiFaceTWO UAC2:249C:930B
UID:AppleUSBAudioEngine:M2Tech:hiFaceTWO UAC2:14200000:1
Active Sample Rate: 48kHz
Sample rate switching latency: 1.5s
Limit bitdepth to 24bit: ON
ID 0x32 hiFaceTWO UAC2 Output
Manufacturer: M2Tech
Model Name: M2Tech hiFaceTWO UAC2 Output
Model UID: hiFaceTWO UAC2:249C:930B
UID: AppleUSBAudioEngine:M2Tech:hiFaceTWO UAC2:14200000:1
Stream ID 0x33 2 channels starting at 1
24 virtual formats:
32 physical formats
Device #0: ID 0x45 Built-in Output Manufacturer: Apple Inc. Model UID: AppleHDA:88 UID: AppleHDAEngineOutput:1B,0,1,2:0 Model Name: Apple Inc. Built-in Output
Device #1: ID 0x32 hiFaceTWO UAC2 Output Manufacturer: M2Tech Model UID: hiFaceTWO UAC2:249C:930B UID: AppleUSBAudioEngine:M2Tech:hiFaceTWO UAC2:14200000:1 Model Name: M2Tech hiFaceTWO UAC2 Output
