Audirvana Origin 1.0.3 (10003)
macOS 10.14.6 with 8GB physical RAM
OFFLINE MODE
Connected account of :
AU plugin #0: Effect - Apple AULowShelfFilter ()
AU plugin #1: None
AU plugin #2: None
AU plugin #3: None
AUTO: /Volumes/FLAC Library/
Library database path: /Users/Useraudio/Library/Application Support/Audirvana/AudirvanaDatabase.sqlite
Max. memory for audio buffers: 1990MB
BENCHMARK DAC2 BENCHMARK DAC2 USB 2.0 AUDIO OUT
Model UID:Benchmark DAC2 USB Audio 2.0:1781:0E4F
UID:AppleUSBAudioEngine:Benchmark DAC2 :Benchmark DAC2 USB Audio 2.0:0000:1
Device: 2ch Non-mixable linear PCM Interleaved 24bits little endian Signed Integer, 8 bytes per frame 44.1kHz
Hog Mode is on
ID 0x38 Benchmark DAC2 USB 2.0 Audio Out
Manufacturer: Benchmark DAC2
Model Name: Benchmark DAC2 USB 2.0 Audio Out
Model UID: Benchmark DAC2 USB Audio 2.0:1781:0E4F
UID: AppleUSBAudioEngine:Benchmark DAC2 :Benchmark DAC2 USB Audio 2.0:0000:1
Stream ID 0x39 2 channels starting at 1
12 virtual formats:
12 physical formats
Device #0: ID 0x30 Built-in Output Manufacturer: Apple Inc. Model UID: AppleHDA:82 UID: AppleHDAEngineOutput:1B,0,1,1:0 Model Name: Apple Inc. Built-in Output
Device #1: ID 0x38 Benchmark DAC2 USB 2.0 Audio Out Manufacturer: Benchmark DAC2 Model UID: Benchmark DAC2 USB Audio 2.0:1781:0E4F UID: AppleUSBAudioEngine:Benchmark DAC2 :Benchmark DAC2 USB Audio 2.0:0000:1 Model Name: Benchmark DAC2 USB 2.0 Audio Out
UPnP not started
