Hegel 120
Dzień dobry, jest to moje drugie podejście do Audirvany ale problem ten sam. Korzystam z Maca Mini a mój wzmacniacz to Hegel 120. Muzyka z Tidal działa tylko w 16/44. Nic więcej nie działa, niby czas na odtwarzaczu idzie do przodu ale muzyka nie gra. Nie jest to problem internetu ponieważ posiadam światłowód. Dla przykładu jak słucham muzyki przez JPlay wszystko jest ok. Jaka może być przyczyna problemu?
Hi @MarcinSz,
Audirvana Studio 2.8.2 (20802)
macOS 14.6.1 with 8GB physical RAM
Connected account of : Marcin Szyperski
Sync list: 0 folders
Library database path: /Users/marcin/Library/Application Support/Audirvana/AudirvanaDatabase.sqlite
Tracks with no MBID: 11
Listening on 127.0.0.1 on port 49154
TIDAL: Connected as PREMIUM
Font size: regular
My Music
Radios
Podcasts
Streaming
Use Apple Remote: yes
Number of paired remotes: 0
Screen saver disabled: no
Active method: UPnP
Preferred device: [UPnP] H120D316C4 Model UID:Hegel H120 UID:uuid:2052295c-1dd2-11b2-aea7-e1eaa00d7a30
Currently playing to UPnP device at 24 bits 96kHz
Selected device:H120D316C4
Manufacturer: Hegel
Model name: H120
Model UID: Hegel H120
UID: uuid:2052295c-1dd2-11b2-aea7-e1eaa00d7a30
UPnP device at http://192.168.100.80:38400/description.xml
ID 0x0
Volume control: Yes
UPnP set capabilities
Maximum PCM frequency set: 96000Hz
Maximum PCM bitdepth set: 24
Not native DSD capable
Avoid RAW PCM streams: No
Unwanted playback stop workaround: Yes
http-get:
:audio/L16;rate=44100;channels=2:DLNA.ORG_PN=LPCM
http-get:
:audio/L16;rate=48000;channels=2:DLNA.ORG_PN=LPCM
http-get:
:audio/x-ms-wma:DLNA.ORG_PN=WMABASE
http-get:
:audio/x-ms-wma:DLNA.ORG_PN=WMAPRO
http-get:
:audio/3gpp:DLNA.ORG_PN=AAC_ISO
http-get:
:audio/3gpp:DLNA.ORG_PN=AAC_ISO_320
http-get:
:audio/vnd.dlna.adts:DLNA.ORG_PN=AAC_ADTS_320
http-get::audio/flac:
http-get::audio/x-flac:
http-get::audio/wav:
http-get::audio/x-wav:
http-get::application/ogg:
DLNA 1.5: Yes
Native Gapless playback: Yes
Universal Gapless playback active: Yes
Missing events workaround: No
Can play native DSD: No
Volume Control: scalar
8 virtual formats:
0 physical formats
NrTracks: 1
MediaDuration: 1:02:08.000
CurrentURI: http://192.168.100.114:49152/audirvana/gaplessAudio_f_0.wav
CurrentURIMetadata:
dc:titleAudirvana gapless playback</dc:title>
nextURI:
nextURIMetadata:
PlayMedium: NETWORK
Current transport actions:
Pause,Stop,Seek,X_DLNA_SeekTime
<?xml version="1.0"?> 1 0 DMR-1.50 urn:schemas-upnp-org:device:MediaRenderer:1 H120D316C4 Hegel http://www.hegel.com H120 H120 1.0 http://www.hegel.com uuid:2052295c-1dd2-11b2-aea7-e1eaa00d7a30 http://192.168.100.80 urn:schemas-upnp-org:service:RenderingControl:1 urn:upnp-org:serviceId:RenderingControl /RenderingControl.xml /RenderingControl /RenderingControl/eventSub urn:schemas-upnp-org:service:AVTransport:1 urn:upnp-org:serviceId:AVTransport /AVTransport.xml /AVTransport /AVTransport/eventSub urn:schemas-upnp-org:service:ConnectionManager:1 urn:upnp-org:serviceId:ConnectionManager /ConnectionManager.xml /ConnectionManager /ConnectionManager/eventSub http://192.168.100.80:38400
UPnP devices found : 1
Device #0: ID 0x0 : H120D316C4
Manufacturer: Hegel
Model name: H120
Local Audio Engine: CoreAudio
Device #0: ID 0x35 DELL U2723QE
Manufacturer: DEL
Model UID: 10AC6D42-0000-0000-1721-0104B53C2278
Model name: DELL U2723QE
Device #1: ID 0x5b Głośniki (Mac mini)
Model UID: Speaker
UID: BuiltInSpeakerDevice
Model name: Apple Inc. Głośniki (Mac mini)
Chromecast devices found : 1
Device #0: SONY KD-55XG9505
Model name: BRAVIA 4K UR2
Hi @MarcinSz,
Your settings seem to be good. Can you send a screenshot of Audirvāna Studio while you have this behavior?
Dzień dobry, wszystko jest już w porządku. Przyczyną całego zamieszania był router wi-fi, po wymianie na nowy jest ok.
