@stefano_mbp
Yes, thank you:
Audirvana Mac Version 3.5.37 (3567)
macOS 10.14.6 with 16384MB RAM
Registered to Garett Rostkowski
AUTO: /Volumes/KEKOA/
Library database path: /Users/sumikobraun/Library/Application Support/Audirvana/AudirvanaPlusDatabaseV2.sqlite
Yamaha USB DAC
Model UID:YamahaUSBAudioDevice2:Yamaha Steinberg USB
UID:YamahaUSBAudioEngine2:0499:3111:0100:Yamaha USB DAC:L-14100000
Device: 2ch Mixable linear PCM Interleaved 32bits little endian Signed Float, 8 bytes per frame 176.4kHz
Active Sample Rate: 176.4kHz
Hog Mode is on
ID 0x39 Yamaha USB DAC Manufacturer:Yamaha
Model UID:YamahaUSBAudioDevice2:Yamaha Steinberg USB UID:YamahaUSBAudioEngine2:0499:3111:0100:Yamaha USB DAC:L-14200000
Stream ID 0x3a 2 channels starting at 1
8 virtual formats:
8 physical formats
Device #0: ID 0x2f Built-in Output Manufacturer: Apple Inc. Model UID: AppleHDA:128 UID: AppleHDAEngineOutput:1B,0,1,1:0
Device #1: ID 0x39 Yamaha USB DAC Manufacturer: Yamaha Model UID: YamahaUSBAudioDevice2:Yamaha Steinberg USB UID: YamahaUSBAudioEngine2:0499:3111:0100:Yamaha USB DAC:L-14200000
