Audirvana 3.5.43
SW volume control: ON
AUTO: \NASSTEVEVIRUS\Public
Library database path: C:\Users\User\AppData\Local\Audirvana\AudirvanaPlus\AudirvanaPlusDatabaseV2.sqlite
Preferred device: sa-link [LINK] Model UID:JF Light Industries sa-link [LINK] UID:uuid:acbb4667-42b5-a9a2-46e7-b827eb749f64
UPnP device at http://192.168.2.135:49152/uuid-acbb4667-42b5-a9a2-46e7-b827eb749f64/description.xml
sa-link [LINK] Manufacturer:JF Light Industries
Volume control: No
DSD capability: Raw DSD (MSB)
http-get::application/flac:*
http-get::application/x-flac:
http-get::application/ogg:
http-get::audio/flac:
http-get::audio/x-flac:
http-get::audio/aac:
http-get::audio/x-aiff:
http-get::audio/aif:
http-get::audio/aiff:
http-get::audio/dff:
http-get::audio/x-dff:
http-get::audio/dsd:
http-get::audio/x-dsd:
http-get::audio/dsf:
http-get::audio/x-dsf:
http-get::audio/m4a:
http-get::audio/x-m4a:
http-get::audio/matroska:
http-get::audio/x-matroska:
http-get::audio/mp1:
http-get::audio/mp4:
http-get::audio/mpeg:
http-get::audio/x-mpeg:
http-get::audio/ogg:
http-get::audio/vorbis:
http-get::audio/x-ape:
http-get::audio/ape:
http-get::audio/wav:
http-get::audio/x-wav:
http-get::audio/wave:
http-get::audio/x-ms-wma:
http-get::audio/x-ogg:
http-get::audio/x-scpls:
http-get::audio/x-vorbis+ogg:
http-get::audio/x-vorbis:
http-get::audio/x-wavpack:
http-get::video/mp4:
DLNA 1.5: No
Gapless playback: Yes
Can play native DSD: Yes
2 ch Integer PCM 24bit little endian 352.8kHz
2 ch Integer PCM 24bit little endian 705.6kHz
2 ch Integer PCM 24bit little endian 384kHz
2 ch Integer PCM 24bit little endian 768kHz
2 ch DSD 8bit little endian in 8bit chunk 2822.4kHz
NrTracks: 1
MediaDuration: 00:00:00
CurrentURI:
CurrentURIMetadata:
nextURI: http://192.168.2.146:49152/audirvana/audio_0_88.wav
nextURIMetadata:
PlayMedium: NONE
<?xml version="1.0"?>
1
0
TransportState
no
string
STOPPED
PLAYING
TransportStatus
no
string
OK
ERROR_OCCURRED
PlaybackStorageMedium
no
string
PossiblePlaybackStorageMedia
no
string
RecordStorageMedium
no
string
PossibleRecordStorageMedia
no
string
CurrentPlayMode
no
string
NORMAL
SHUFFLE
REPEAT_ONE
REPEAT_ALL
RANDOM
DIRECT_1
NORMAL
TransportPlaySpeed
no
string
1
no
RecordMediumWriteStatus
string
CurrentRecordQualityMode
no
string
PossibleRecordQualityModes
no
string
NumberOfTracks
no
ui4
0
2000
1
CurrentTrack
no
ui4
0
2000
1
CurrentTrackDuration
no
string
CurrentMediaDuration
no
string
CurrentTrackMetaData
no
string
CurrentTrackURI
no
string
AVTransportURI
no
string
AVTransportURIMetaData
no
string
NextAVTransportURI
no
string
NextAVTransportURIMetaData
no
string
RelativeTimePosition
no
string
AbsoluteTimePosition
no
string
RelativeCounterPosition
no
i4
AbsoluteCounterPosition
no
i4
CurrentTransportActions
no
string
LastChange
yes
string
A_ARG_TYPE_SeekMode
no
string
ABS_TIME
REL_TIME
A_ARG_TYPE_SeekTarget
no
string
A_ARG_TYPE_InstanceID
no
ui4
SetAVTransportURI
InstanceID
in
CurrentURI
in
AVTransportURI
CurrentURIMetaData
in
SetNextAVTransportURI
InstanceID
in
NextURI
in
NextAVTransportURI
NextURIMetaData
in
GetMediaInfo
InstanceID
in
NrTracks
out
NumberOfTracks
MediaDuration
out
CurrentURI
out
AVTransportURI
CurrentURIMetaData
out
NextURI
out
NextAVTransportURI
NextURIMetaData
out
PlayMedium
out
RecordMedium
out
RecordStorageMedium
WriteStatus
out
GetTransportInfo
InstanceID
in
CurrentTransportState
out
TransportState
out
TransportStatus
CurrentSpeed
out
TransportPlaySpeed
GetPositionInfo
InstanceID
in
Track
out
CurrentTrack
TrackDuration
out
TrackMetaData
out
TrackURI
out
CurrentTrackURI
RelTime
out
AbsTime
out
RelCount
out
AbsCount
out
GetDeviceCapabilities
InstanceID
in
PlayMedia
out
RecMedia
out
RecQualityModes
out
GetTransportSettings
InstanceID
in
PlayMode
out
CurrentPlayMode
RecQualityMode
out
Stop
InstanceID
in
Play
InstanceID
in
Speed
in
TransportPlaySpeed
Pause
InstanceID
in
Seek
InstanceID
in
Unit
in
A_ARG_TYPE_SeekMode
Target
in
Next
InstanceID
in
Previous
InstanceID
in
SetPlayMode
InstanceID
in
NewPlayMode
in
CurrentPlayMode
GetCurrentTransportActions
InstanceID
in
Actions
out
1
1
sa-link [LINK]
JF Light Industries
https://framagit.org/medoc92
UPnP front-end to MPD
UpMPD
42
https://framagit.org/medoc92/upmpdcli/code/
upmpdcli version 1.4.14 libupnpp 0.20.1
image/png
64
64
32
/uuid-acbb4667-42b5-a9a2-46e7-b827eb749f64/icon.png
/uuid-acbb4667-42b5-a9a2-46e7-b827eb749f64/presentation.html
/uuid-acbb4667-42b5-a9a2-46e7-b827eb749f64/urn-schemas-upnp-org-service-AVTransport-1.xml
/uuid-acbb4667-42b5-a9a2-46e7-b827eb749f64/ctl-urn-schemas-upnp-org-service-AVTransport-1
/uuid-acbb4667-42b5-a9a2-46e7-b827eb749f64/evt-urn-schemas-upnp-org-service-AVTransport-1
/uuid-acbb4667-42b5-a9a2-46e7-b827eb749f64/urn-schemas-upnp-org-service-RenderingControl-1.xml
/uuid-acbb4667-42b5-a9a2-46e7-b827eb749f64/ctl-urn-schemas-upnp-org-service-RenderingControl-1
/uuid-acbb4667-42b5-a9a2-46e7-b827eb749f64/evt-urn-schemas-upnp-org-service-RenderingControl-1
/uuid-acbb4667-42b5-a9a2-46e7-b827eb749f64/urn-schemas-upnp-org-service-ConnectionManager-1.xml
/uuid-acbb4667-42b5-a9a2-46e7-b827eb749f64/ctl-urn-schemas-upnp-org-service-ConnectionManager-1
/uuid-acbb4667-42b5-a9a2-46e7-b827eb749f64/evt-urn-schemas-upnp-org-service-ConnectionManager-1
urn:av-openhome-org:service:Info:1
urn:av-openhome-org:serviceId:Info
/uuid-acbb4667-42b5-a9a2-46e7-b827eb749f64/urn-av-openhome-org-service-Info-1.xml
/uuid-acbb4667-42b5-a9a2-46e7-b827eb749f64/ctl-urn-av-openhome-org-service-Info-1
/uuid-acbb4667-42b5-a9a2-46e7-b827eb749f64/evt-urn-av-openhome-org-service-Info-1
urn:av-openhome-org:service:Time:1
urn:av-openhome-org:serviceId:Time
/uuid-acbb4667-42b5-a9a2-46e7-b827eb749f64/urn-av-openhome-org-service-Time-1.xml
/uuid-acbb4667-42b5-a9a2-46e7-b827eb749f64/ctl-urn-av-openhome-org-service-Time-1
/uuid-acbb4667-42b5-a9a2-46e7-b827eb749f64/evt-urn-av-openhome-org-service-Time-1
urn:av-openhome-org:service:Volume:1
urn:av-openhome-org:serviceId:Volume
/uuid-acbb4667-42b5-a9a2-46e7-b827eb749f64/urn-av-openhome-org-service-Volume-1.xml
/uuid-acbb4667-42b5-a9a2-46e7-b827eb749f64/ctl-urn-av-openhome-org-service-Volume-1
/uuid-acbb4667-42b5-a9a2-46e7-b827eb749f64/evt-urn-av-openhome-org-service-Volume-1
urn:av-openhome-org:service:Credentials:1
urn:av-openhome-org:serviceId:Credentials
/uuid-acbb4667-42b5-a9a2-46e7-b827eb749f64/urn-av-openhome-org-service-Credentials-1.xml
/uuid-acbb4667-42b5-a9a2-46e7-b827eb749f64/ctl-urn-av-openhome-org-service-Credentials-1
/uuid-acbb4667-42b5-a9a2-46e7-b827eb749f64/evt-urn-av-openhome-org-service-Credentials-1
urn:av-openhome-org:service:Playlist:1
urn:av-openhome-org:serviceId:Playlist
/uuid-acbb4667-42b5-a9a2-46e7-b827eb749f64/urn-av-openhome-org-service-Playlist-1.xml
/uuid-acbb4667-42b5-a9a2-46e7-b827eb749f64/ctl-urn-av-openhome-org-service-Playlist-1
/uuid-acbb4667-42b5-a9a2-46e7-b827eb749f64/evt-urn-av-openhome-org-service-Playlist-1
urn:av-openhome-org:service:Radio:1
urn:av-openhome-org:serviceId:Radio
/uuid-acbb4667-42b5-a9a2-46e7-b827eb749f64/urn-av-openhome-org-service-Radio-1.xml
/uuid-acbb4667-42b5-a9a2-46e7-b827eb749f64/ctl-urn-av-openhome-org-service-Radio-1
/uuid-acbb4667-42b5-a9a2-46e7-b827eb749f64/evt-urn-av-openhome-org-service-Radio-1
urn:av-openhome-org:service:Product:2
urn:av-openhome-org:serviceId:Product
/uuid-acbb4667-42b5-a9a2-46e7-b827eb749f64/urn-av-openhome-org-service-Product-2.xml
/uuid-acbb4667-42b5-a9a2-46e7-b827eb749f64/ctl-urn-av-openhome-org-service-Product-2
/uuid-acbb4667-42b5-a9a2-46e7-b827eb749f64/evt-urn-av-openhome-org-service-Product-2
UPnP devices found : 2
Device #0sa-link [LINK] UID: uuid:acbb4667-42b5-a9a2-46e7-b827eb749f64 Location: http://192.168.2.135:49152/uuid-acbb4667-42b5-a9a2-46e7-b827eb749f64/description.xml
Device #1[TV]Samsung LED40 UID: uuid:173eed82-0086-1000-971c-bc14853c92b1 Location: http://192.168.2.92:7676/smp_19_
Max. memory for audio buffers: 4002MB
Local Audio Engine:ASIO -1 driver version -1
Device #0: ASIO4ALL v2 Manufacturer: Model UID: ASIO4ALL v2 UID: ASIO4ALL v2
