Hi-Res albums not listed
Hi there!
A lot of my local Hi-Res albums are not listed under Local/Hi-Res. Why is that?
Some more details about your setup could be useful to help you:
Which version are you running (Studio, Origin)?
Where are your albums located (nas, hdd/usb)?
Have you defined the right paths in the library?
Are there other albums in the same path/s that are correctly listed?
Which file type are the not listed albums?
Are other albums with the same file type correctly listed?
Studio, 2.3.4, Windows 10
Micro-SD, local
Yes
Yes
It’s Flac all over
Yes
Can you verify the access rights of those not listed albums?
No. Seems I can’t :slightly_frowning_face:
Very strange … can you use, just for troubleshooting, a usb pendrive or a hdd? The microSD could be the primary issue, the are quite “fragile”
I tried that out, with the same result.
Just to make that clear: Audirvāna can play those missing Hi-Res tunes, all right. The only problem is: They are not listed correctly under Local/Hi-Res.
Hi @Audi100,
Can you send us a mail at [email protected] with some examples? I would like to look at your database file. I will send you a link to upload it so I can look at it.
What do you mean with “ not listed correctly “? This is different from “not listed.” as you stated in your first post
Should be with you in a minute.
OK – it was all my fault. I had some filters active, showing only a certain type of hi-res tunes … :see_no_evil:
Sorry, and thanks a lot to Audirvāna Support Team for looking into this »case«.
