Do you pay a one time fee or is it yearly?
Is it just for V3.5? Do you have to buy a new key when they upgrade the software?
Or do you completed access to the software for a one time fee of 100 bucks?
Hello @Inkey31,
You pay for the latest major update of Audirvana. Actually we are in Audirvana 3.5. You own the key so you will still be able to use it even if we release a major update. If you then are interested in this major update you’ll have a preferred price to buy it.
Great, thank you so much.
So you buy the latest release for 100 bucks, then when you update the software I get a discount on that basically?
So, its done by major release, I am assuming features and what not? Is the major release I buy supported? Do you patch for critical updates, such as security risks?
John
Exactly, this is how Audirvana works.
If you buy Audirvana now you’ll get the 3.5 version which is the latest major update we had.
The “purchase” function on the website is disabled.
Does anyone know what’s going on?
Thank you for your message.
Yes, there was an issue with our website optimization services and we have just fixed the issue.
You can now purchase Audirvana on https://audirvana.com/buy/
Have a nice week-end with Audirvana.
