I Can not figure out how to add a MUSIC FOLDER WHICH IS NOT UNDER MY MUSIC
Top right the three horizontal lines, are the preferences, click on library tab there and then add a folder
Not quite sure if they are talking about the same thing, but ‘My Music’ are your favorites from all sources. Local and Streaming. If you want to add something, you have to click on the favorites ‘heart’.
