Is there a way to assign eq settings (or more generally, the processing pipeline) to specific songs or playlists so I don’t have to adjust it each time a song starts (eg when shuffling through favourites?)
Hello @luzhin,
This is not possible to do such thing with Studio. Implementing such thing could be really difficult, we then recommend you to use the preset of the EQ as this is the fastest way to change your EQ settings between two songs.
Okay, thanks for confirming. I’m using presets currently, but would’ve loved to see it switch automatically based on whats playing.
