How to avoid AS going into sleep mode?
I´d like that my Mac stays ON when I play AS. Is that a feature in AS or elsewhere possible without going in Macosx´s Prefs every time?
Sorry if this has been discused before, I just could not find the answer…
Best KK
You can try those settings…
my mac is for music and i don’t use a real screen…
so no need for screen saver…
These settings might be different on your mac…
this is with Sequoia 15.2
Yes, thanks. But I wanted a Don´t Go InTo Sleep Mode ONLY when I use Audirvana. :grinning:
I found this in AS prefs:
