Need a simple way to choose L/R balance… How?
there is surely a free AU plugin that do that… but i don’t know.
if on a mac, does this help…
Audio Midi Setup in your utilities folder in the Applications folder…
you can reduce a channel there…
I like that, it looks great, unfortunately, I’m using an external dac. And also, I am using windows 10
can you right click your speaker icon in windows bar… it gives options there
Trying now.
Also I’m using a usb to optical converter. So my dac bits are needed to stay at 24.
But how do I change that.
It appears right now it’s dac bits 32…
I love audirvana far more Than roon
not a windows expert… but Audirvana show the number your dac is able to reproduce on the right…
if you are not upsampling in the preferences, that song at 16/44 is playing at 16/44…
but shows on the right 32/44 because your DAC is 32 bits.
on the right of main computer window… below on the remote
Don’t worry, it’s just what USB interface reports to Audirvana.
So this is what I got… Nowhere I can control the left and right balance…
I’m sure it’s me… I just want to learn
