don’t know what I did. All of a sudden my volume is super low.The max volume shows 0db. I can hear during playback, but barely audible. Looked at volume setting and the max I can set it at is 0db. I obviously did something.
Any ideas? I’m bummed out—I just got new headphones and can’t play anything. I’m using Fabfilter and have it set at -8db, and have enable software volume It worked fine before
Please paste your debug information report here, so folks can help the best possible… it is found here: Settings–> My Account–> Help–> Debug info
Do you have a hardware or software volume control on your pre-amp/amp and/or your DAC?
I’m using a portable DAP ( that operates on Windows. It does have a volume control which is working
sorry about being stupid. Where are settings?On the screen to the left (that starts as Audirvana.com, About, Topics) and go down to My Audirvana account, there is nowhere that I can find “help” or “debug information”
In the Audirvana player screen… or can be accessed via the Audirvana Menu option in the player window Menu bar…
Use your volume control on the DAP and disable the Audirvana software volume controls.
Hi @mikearnopol,
It’s in the Audirvāna Studio app you will find the debug info.
I found the screen with the debug info. There is also a contact button. When I press it it goes to Outlook ( which I don’t use) and then that screen turns off. It won’t go to Gmail. I’m really sorry that I’m a bit clueless, but I just got new headphones and I’d love to get it working. I’ve turned off and on the software volume control. if you’re French, you might be familiar with jazz vocalist Patricia Barber—I’m an all but the last recording
Copy and paste the debug information into a new response here in this thread…
What does the DAP manufacturer say about the behavior you are experiencing?
Audirvana Studio 2.9.4 (20904)
Windows 11 (22631) x86_64 with 8GB physical RAM
Connected account of : Michael Arnopol
Available network interfaces:
以太网 4 ({90b2e579-2cf4-436c-a68f-6b39c0a50e6c}) is PUBLIC
Active profile types: all
Private profile:
Firewall: enabled
Inbound: blocked
Outbound: allowed
Notifications: enabled
Public profile:
Firewall: enabled
Inbound: allowed
Outbound: allowed
VST3 plugin #0: C:\Program Files\Common Files\VST3\FabFilter Pro-Q 3.vst3
ClassID: 72C4DB717A4D459AB97E51745D84B39D
VST3 plugin #1: None
VST3 plugin #2: None
Please paste your complete debug report here…
