How to sort Playlist by Last/First Added and Name
This might have been solved before, I just don’t know where… Best Regards Mit freundlichen Grüssen Kurt L :smile:
Hi @KnockKnock,
Maybe you are looking for this?
Yes, that´s GREAT, but does it not work on the Qobuz playlists? I have loads, and sometimes want to revert to the last used. After some days I want to switch back to Alphabetical order.
In this case that’s not possible, simply because Qobuz do not use this metadata at all. We can’t use this metadata because they seems to not store it. Which is why you can’t do such sort in their app itself :confused:
But yes they do, see screenshot
I mean in a playlist, not the list of playlist :wink:
