IFI Zen DAC 3 DSD512 issue
I’ve just bought and received the IFI Zen DAC 3.
I noticed Audirvana doesn’t deem it able to do DSD512.
What gives?
Debug info:
Audirvana Studio 2.9.2 (20902)
Windows 11 (22631) with 32GB physical RAM
Connected account of : Peter Andersen
Available network interfaces:
FUGL_5G ({495fc74b-e2cf-4bd1-9cf7-eb3a6e3e9572}) is PUBLIC
Active profile types: all
Private profile:
Firewall: enabled
Inbound: blocked
Outbound: allowed
Notifications: enabled
Public profile:
Firewall: enabled
Inbound: allowed
Outbound: allowed
r8brain with 2x upsampling
Sync list: 4 folders
AUTO: C:\Users\peter\Music
AUTO: D:\Movie&Game OST FLAC
AUTO: D:\Music
AUTO: E:
Library database path: C:\Users\peter\AppData\Local\Packages\Audirvana.Audirvana-4118-9684-d80dbb7827cd_q3nymrkmej12j\LocalCache\Local\Audirvana\Audirvana\AudirvanaDatabase.sqlite
Tracks with no MBID: 3725
Listening on 2001:fb1:7e:4043:2912:47c0:7d5c:6d2e on port 50241
TIDAL: Connected as PREMIUM
Font size: large
My Music
Radios
Podcasts
Streaming
Number of paired remotes: 0
Screen saver disabled: no
Max. memory for audio buffers: 16384MB
Højttalere (ZEN DAC 3)
Model UID:USB\VID_20B1&PID_3009&REV_0103&MI_00
UID:\?\SWD#MMDEVAPI#{0.0.0.00000000}.{dc755e2c-4b2f-4222-b0b9-f699c1441470}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
Selected device:Højttalere (ZEN DAC 3)
Manufacturer: Microsoft
Model name: ZEN DAC 3
Model UID: USB\VID_20B1&PID_3009&REV_0103&MI_00
UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{dc755e2c-4b2f-4222-b0b9-f699c1441470}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
USB Vendor ID: 0x20b1
USB Product ID: 0x3009
Kernel Streaming capable
DSD via PCM 1.1
Simple stereo device: No
2 ch Integer PCM 24bit little endian 352.8kHz
2 ch Integer PCM 24bit little endian 384kHz
2 ch Integer PCM 24bit little endian 705.6kHz
2 ch Integer PCM 24bit little endian 768kHz
Local devices found : 5
Device #0: Højttalere (ZEN DAC 3)
Device #1: Højttalere (Realtek(R) Audio)
Manufacturer: Realtek
Model UID: INTELAUDIO\FUNC_01&VEN_10EC&DEV_0256&SUBSYS_104316F2&REV_1000
UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{dfbcfb59-b49b-4abd-84e0-50fee7defb4a}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
Model name: Intel High Definition Audio
Device #2: Hovedtelefoner (Realtek(R) Audio)
UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{0d19f208-3f73-46e5-8a73-00b3502acaa9}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
Device #3: 24G2W1G4 (HD Audio Driver for Display Audio)
Manufacturer: Intel Corporation
Model UID: HDAUDIO\SUBFUNC_01&VEN_8086&DEV_2812&NID_0001&SUBSYS_00000000&REV_1000
UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{f1053d00-487c-4abf-80ff-eb0f99c39c0c}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
Model name: HDAUDIO\SUBFUNC_01&VEN_8086&DEV_2812&NID_0001&SUBSYS_00000000&REV_1000
Device #4: AI Noise-cancelling Output (ASUS Utility)
Manufacturer: ASUSTek Computer Inc.
Model UID: *IGOVAC
UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{3868187d-df4c-485b-9808-d89fec9be38c}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
Model name: Unknown model
Not an expert on windows but you are using Kernel Streaming which only supports DSD over DOP (your setting appears to be DOP1.1) this I think limits you to DSD256. If you install the ASIO driver for your device and play over ASIO then you can play native DSD which will facilitate the max capability of your DAC at DSD512
That worked, thanks:=)
Welcome… @Peter_Andersen
Regarding DoP playback…
Note the Bold highlighted sample-rate support for your DAC…
The reason you cannot play 22.4MHz (DSD512) via DoP 1.1 is because the DAC supports up-to the DoP PCM carrier sample-rate for 11.2MHZ (DSD256) which is 705.6kHz…
The DoP 1.1 PCM carrier sample-rate for (22.4MHz) DSD512 is 1411.2kHz.
